Slippy rear!!
Slippy rear!!
Hi there,
I've been out of RC now for quite some time, and now im looking break out my Vone RRR. Now iv always found the rear of the car to step out a far bit!, more so than most other cars and I was fairly new to setting up a car like this with very little help from anyone, but I have a cut feeling it might be the rear diff oil weight, a standard set up which is more than likely what I have says 30000, was wondering with the vast knowledge from you guys, would you be able to shed a little light on my problem,maybe someone out there found the standard setup doing the same thing to them, if so how did ya sort it?. Only new to this forum so please help
Many thanks, Jayo
Many thanks, Jayo
Try harder front suspension oil, harder spring, or thinner/softer at the rear.
Try also stand up the front shock/lay down the rear one.
Tuning is part of the fun. Have fun!
not forgetting the tires!
try harder fronts or softer rears...
