Tamiya TB-03
#1473
i have done in this way: first i chenged the dif case with the ones carbon reinforced as when you housing the gear you will find less play, then a shimmed to zero play, and then i made 2 batteries of break in, i checked once more the ammount of play, everything was ok.
Ciao
Max
#1474
Awesome kit TB03
My TBO3 on a low traction parking lot track! this car is awesome right out of the box. I am so impressed!
Hopups used,
1. SPOOL
2. TRF SHOCKS
3. SPRINGS
I am the only one running a 13.5T motor against 11.5T, 10.5T and 9T motors. my TB03 was very fast pls check the video! (white car)
http://www.youtube.com/watch?v=aurx8vM8UE4
Hopups used,
1. SPOOL
2. TRF SHOCKS
3. SPRINGS
#1475
Ciao Bersek,
i saw yr video, very impressive, are you sure that you was running a 13.5T ?, which motor are you using, and which was your fdr?
Ciao
Max
Ciao
Max
#1477
Need a bit of help and the search is not cooperating with me this morning. Im looking for a sway bar set and Im sure its listed here somewhere. I want to order the TA-53842 TA05 set. Is there any reason these wont fit? The arms look the same. I need to order them today so I can have them for thursday to race with.
David
David
#1478
David
David
#1479
Hello and hi to all TB03 owners.
FYI, I am a TB03D owner and I play drift. Can any of you guys mine sharing me your set up? TA-05 owners are welcome too since TA05 and TB03 sharing almost all hop ups.
My current set up.
Toe: Front 0, Rear -3
Camber: Front 0, Rear -1
Height: Front 4, Rear 5
Spring: Front hard, Rear medium
Front and rear using ball differential. Front loose, rear semi tight.
Yokomo one way shaft installed replacing the stock shaft (it fits!)
My car is really under steer, hard to take hairpin/sharp corners and I feel like that my car has it own D box :S and I dont like it. In order to get into such corners, I have to brake hard to make my car turn side ways.
Help please, idea, suggestions, tips etc are all welcome. I am desperate.
Would like to share some, soon I am getting myself a 3 racing spool to replace the rear ball diff and a 3 racing suspension for TA-05. What do you guys think?
My current set up.
#1480
Need some Shock Spring help
Recently purchased a TB03 and I am having lots of fun. I have tuned the suspension as far as I can go without changing things.
I can't seem to find shocks for it. I would like to buy a set, from soft to hard so I can tune the chassis response. Where do I get them and what is the part number.
I have looked on the Tamiya sight but I can't find them there. Also Tower hobbies doesn't seem to have them.
Help would be appreciated.
Jim
Jim
#1481
Jim
Jim
he stocks all of the parts you need for Tamiya cars, esp the TB-03.
#1482
My current set up.
My current set up.
If this car is for drift only I would go spool front and tighten up the rear diff a bit more. Also change the springs around and go medium front, hard rear and toe the front out a degree or two to start.
#1483
Jim
Jim
http://www.tamiyausa.com/product/ite...oduct-id=49355
Spring set to go with them are these:
http://www.tamiyausa.com/product/ite...oduct-id=49389
Sway Bars here:
http://www.tamiyausa.com/product/ite...oduct-id=53842
#1485
Hey guys, I had a major problem today with my TB-03D.
The metal pin that goes in my Tamiya Steel CVDs snapped in half and got jammed in my hubs. The one that is tightened down by the hex screw that connects the dogbone to the thread drive shaft that the wheel bolts onto.
I fixed replaced the the pin. I thought it was caused by stress I just stuck an EZrun into my car.
I picked up the car and and tested out the car and the car runs smooth until I test the steering. Everything runs smooths while turning except the left side looking at the front of the car.
The wheels vibrates like crazy and you can feels the vibrations byt he sound it makes in your ear flabbing around at throttle.If the car steering is neutral(going straight) then it's fine. It only vibrates wildly when I turn half way down.
I checked everything. Everything seems fine. My dog bones seems a bit rough when t's turn. DOesn't seem to be caught on anything though.
My setup:
-Tamiya Direct Coupling Front/Rear
-Square RC Center One Way Shaft
UPDATE: I reinstalled everything. Both wheels vibrate when I turn past halfway to the stopper on the hub. And then it vibrates wildly. Never did this before. only thing I did different to it was install Tamiya Direct Coupling.
My setup:
