Tamiya TB-03
#2176
Just scuttlebutt at the hobby shop today. I have seen nothing from Tamiya.
#2177
http://www.tamiyausa.com/items/radio...ssis-kit-84339
#2178
What servo saver works best with the tb03. My tamiya one has play in it and the small kimbrough one I got isn't tall enough. Will the med one do the trick?
#2180
What springs front and rear work best?
Using upright position on front
High grip carpet.
High grip carpet.
#2182
It seems when I have the normal tamiya
Springs in I can only get down to 6mm
Ride height. If I put the short ones in
5mm is easy but it seems weak?
What is everybody else using? Short or
Long
Long
#2186
That makes good sense. I will put the spacers in. Do you put the spacers under the front as well? It seems to be almost at 5 mm.
#2189
Another option is to use spacers inside the shock on the shaft to limit the extension of the shock shaft.
#2190
with short springs and 1mm retainer, i have no problems on the tb03 or 04
