Integy Tire truer
Integy Tire truer
i purchased one and it broke in 3 day's. i contacted them and sent it back and now i get no response from them ..i am out a tire truer . it's been 3 week's ....BeWare of sending anything to them you might not ever get it back..this is my opinion......
the gearing for the cutter slide...would not move in either direction.checked inside and you could hear gear strip..i let someone use it and they tried to take off to much foam at one time..
Integy finally got back to me and they are sending it back Monday.....aaaah what a relief........
I have had mine for more than 3 years now. never had an issue. I did upgrade the slave motor (one that holds the arbor.tire) to a Hudy truer motor and it is a rock solid truer. I had an issue with blowing a few fuses after the upgrade, but solved it. I looked the truer over after reading this, and was curious if the gearing for the cutter slide was plastic or metal... mine was metal.
RCFOOLZ, How did you solve the fuse issue? Also, what type of and where do you get fuses for it?
I also have an issue with the fuses. I cant find them anywhere. does anyone know what voltage the truer is rated for??
since i got it back , iv'e had no futher issues and i'm extremely pleased w/it.............
try Radio Shack
