Kyosho FW-05R
#1036
Originally posted by NetBike
B or people here, I am interested at FW05R because the layout looks the same to my MT2. Do you think I can convert my MT2 into a tourer?
#1037
Location: Costa Del Sol, Marbella, Spain www.bradir.net
IDM
Originally posted by AMGRacer
Interesting results from Italy. Fransesco is really taking it too them with the FW05.
http://www.novarossi.it/21_3_04.htm
Has anybody here seen the IDM range of motors?
IDM - check out the nuremburg show, i saw a pic with IDM AAC engines too
#1038
Originally posted by orangbaligila
number 2) tried this and not good on crashes 'n bigger collisions (w/ other car),.... too tight will break your shock tower instead,.... just make sure you use new ball ends on every race,... it won't pop off that often,... if it does, it's better than changing a shock tower in a middle of the race, right?! for better snug fit on the balls (no sick intentions here, hehe) try using titanium ball-ends
#1039
It all done and now i need to test it..
Almost all stock except the upper deck - 3racing, and modified lefty to right pipe and manifold.
There are afew plans in my mind
1) To change the rear upride to Mugen upride ( Which i done to my V1RR Evo to M1RR Evo )
2) Change the ring gear to steel ring gear.
3) Change the dogbone to UJ
4) Change that plastic wheel adapter
5) Change that plastic pivot ball stopper
6) Change the chasis
7) Change the rear upride link to V1RR link
#1040
very pretty car. what is the engine on your car ? the heatsink looks funny
#1041
#1042
#1044
Originally posted by B
browse throught the V one R forum, they talked about it in detail there.
It gives better performance in short.
#1045
Originally posted by jeffreylin
Okay B, there must be thousands of post in that thread--how about a short why and how? Thanks!
that subject was not talked about long ago.
I would not be the best person to ask however. I think AMGRacer or Manticore or someone that that will be able to give a better explanation.
#1046
Infact Kyosho V1RRR will change their rear hub to "Mugen" alike rear hub. And check the preworld championship recently where Triboni use FW05R with Mugen hub .. ANd he got 1st
But still is up to individual "taste". Even Takuya Ito on that preworld with the orginal rear hub he TQ , fastest lap
#1047
Why the mugen rear upright instead?
With the Mugen uprights, you are able to change the rear roll center by changing the angle of the upper and lower arms.
#1048
Originally posted by InitialD
I may be wrong but I read that the Mugen uprights on the FW05R came from the pictures at the Pre-Worlds on Tironi's FW05R.
Interesting about Tironi's car. Everything else looks pretty stock except the 3Racing alumnium bulkhead. I had other 3Racing alumnium parts on my car but I've now took most out (for weight) leaving only the front bulkhead.
#1050
Originally posted by ATOMIC
H has the front uprights shortened or re-drilled where the turnbuckle conects leaving a much straighter turnbuckle . This affects the ackerman and should give you some steering.
