Kyosho FW-05R
#961
Originally posted by Buddy_C
hi ziggy, it's either the pipe or the engine i would guess by now!
next time i'll dump in a max power (new or used) engine and gotta see for myself! if i get good top speed, will definitely keep the car, if not, back to mtx3!
buddy
buddy
i would suggest getting the kawahara upgrade
#963
Re: Fw05-r
Originally posted by Vr6vroom
Anyone have a fw05 r for sale?
#964
Originally posted by jeffreylin
I agree with the list but I'd add the front Universal and the graphite shock stays. Meanwhile, what is the part number of the hardened brake disk? if you are talking about VZW015 the SP brake disk I wouldn't recomment it. It is thicker than the stock one so you need longer brake pad screw to hold it. But more imporatnatly it's a lot heavier and adds too much weight on the drivetrain. I'd just replace the brake disk every now and then instead.
#965
Originally posted by Bundy_Bear
Racing4evo:
I managed to find the steel ring gear set, they do them in a 39t and a 40t set, what would the difference be? Also what is the problem with the stock brake disk?
Finally, are you talking about the Kawahara front end conversion or just the frnt damper kit?
BB
Racing4evo:
BB
I guess I'm talking about the Front End Conversion. The one that elimanates the Bulkhead Brace/Upper Arm Carrier.
#966
well, of course not, but if it states that the 2nd gear ratio is 5.0 being the lowest, it just shows you that it won't get any faster on the top end dept...
also another question....the pinions are 0.8m but the spurs are 1.0m....? coz i've seen vonerr evo, and their spurs look true 0.8, unlike the 05r's
buddy
buddy
#967
Originally posted by ziggy12345
http://rc-union.com/product_info.php...roducts_id=706
Try this pipe. I have just ordered it
Cheers
Cheers
#968
Changing the pipe makes a big difference. I have the RD Logics pipe for the NRS4-3 and it seriously lacks top end. Both my NS and my mod MT-12 were struggling down the 160ft straight but when those engines are in my Evolution, they're absolutely ballistic. The pipe doesn't solve the problem but it helps a heap. Pipes to use are the Kyosho and the recently released RB one peice. You can find the RB at www.ace-hobbies.com
#969
Originally posted by Racing4Evo
The steel ring gears are stronger and truer than the stock cast ones. I think they are also a little lighter. The 39t ring gears lower the FRD giving you more top end and a little milder acceleration compared to the 40t. The problem with the brake disk is that under acceleration the holes get enlarged by the brake pins.
Just had a look at the Square racing Brake Disk for the FW05-R, looks very impressive?
BB
#970
This is a new shop. Has anyone else ordered from them? I'd like to order some stuff too.
#971
The top pic is the RD logics pipe and the bottom the RB pipe. Look at the difference in length of the manifolds!!
The RD is way too long.
I think the shorter it is the more top end you get right?
Cheers
#972
#973
What are we talking about in length adjustment? mm or cms?
#974
Originally posted by InitialD
You got that right ziggy.
#975
4 more post to go soon to be D tech lord!!!
The pipe length should be in the regions of 90 to 110 mm.
Can't find it anymore but RB used to have a page where it showed how to measure the pipe.
