Kyosho FW-05R
#4666
Originally Posted by InitialD
The FORCE is strong with this one...
#4667
parts
ok guys called kyosho usa today, got my parts from them. not overpriced either. guy on phone was very helpfull. good to deal with the mfgr!
#4668
It doesn't make a difference you still going to get your doors blown off. Ha ha ha haaaa I think I found the door blower tried it out today.
#4669
ok my lil japanese car is gonna blow by you so fast youll think its an f16! muhhahahahahahahahahahahaha
#4670
Originally Posted by Sow&Steady
Indeed it is
#4671
Moderator
a guy we race with at a local track is very fast but also very ... agressive. he had a FW-05R last year (I bought it) and this year went to a NTC3. Well in his first race he took an entire rear wheel assy off the car, and an entire front clip with crashes I would call "harsh" but not that insanely bad. He had similar crashes with the FW... and never broke a part.
From what I hear he's selling his NTC3 now and getting a FW-05RR
#4672
I have owned both the FW-05R and V-one RRR. I have also driven a FW-05RR on several occasions. From my experience both cars are fast but the V-One RRR is much more aggresive while still being forgiving with throttle input. Going from driving a good handling FW-05R to a V-One RRR I noticed I could basically treat the throttle like an on/off switch when compared to the FW. This is a trait that seems to be prevelant in all the shaft cars out there, CD-3, FW-05R/RR, and NTC3. They are much more reactive to throttle changes.
I would stick with whatever car is working really well for you until you are getting your doors blown off by another car(not another driver), then it's time to change.
#4673
#4674
#4675
Hi Guys.....
can someone help me out here.. I am tryin to remove the pinion gears from the clutch bell. whats the easiest way out of this. ITs got me frustrated... I think there is some sort of tool to do so. But i dont have it. so how to do it without the tool - tips please.?
part nos.. ?? if any thing which i should order...
#4676
Originally Posted by uaerc
Hi Guys.....
http://www2.towerhobbies.com/cgi-bin...?&I=LXFVH4&P=X
It's no longer available through Tower so you need to order it from your LHS or wherever you order your parts. The part number is VZW040.
#4677
Josh's RR Set-up
Originally Posted by impalabob64
hey, cow buster the 3r knuckle gives alot of steering.Try dialing out some of your steering,or check your droop settings in the frt,an rear try 0 frt,3rear .Hear in Fla. We use vht,or grape soda,so traction is not a problem at all.You want to here something funny at the Winternat i used Josh,s set that he ran on the fwo5rr,the car was glued to the track on 37shore tires.The serpent,mugens,an Grinders 3r where running 40,42 an some 45 shore so not to traction roll.I ran 37 shore all day.i
[email protected]
If not, that's cool. I'm actally looking for a good set-up for a med-traction track that's about 160 x 90 (tight in-field).
Thanks a lot! Tommy
#4679
Originally Posted by mrgsr
hi guys
i will be doing some racing at another local track that has a rather long straight.
where is the best place online to buy 37t ring gears from ?
do these ring gears only come in steel ? i wouldnt mind the normal aluminium ones
John
John
#4680
I still have problems mounting my 37t ring gears correctly. I mounted the shim on the outside of the gear-housing and it worked ok, but after i upgraded to the blue center shafts supplied with the r-kit the rear one locks because there is no axial space left.
When i put the shim on the inside it seems that the smaller ring gear rubbs the edge of the diff-housing which holds the rubber-seal in place.
Best regards,
Robert
Best regards,
Robert
