Kyosho FW-05R
#3841
This was Josh Cyrul's car at the 2004 Nationals. It clearly an RR.
#3842
Originally posted by Clegg
1) Is there a Graphite front shock tower for the RR yet?
2) Does anyone make a hex head Ti screw set for the FW-05R? I see Speedmind has a Ti set but I fear they are philips head.
3) Should the Centax clutch shoe be replaced (it was used for a full season), and if so what color shoe's mean what?
2) Speedmind Ti is soft, I've had to bin most of them after they stripped, Tamiya is much stronger but only does cross head.
3) I'm still running the original clutch shoe, and have done over 100 hours of running with this car.
Grey = Soft Take Up
Black = Standard Kit
Red = Sharp Take Up
#3843
Moderator
THank you thats exactly the info I wanted!!
Also has anyone ordered from www.rc-union.com? they seem to have the RR conversion in stock (the only place I have found with it in stock)
#3845
(got mine from Japan on Dec 6th)
#3846
josh cyrul picture
Hi ,on the Josh Cyrul car's picture you can see a canister install on the pressure line it's a standard fuel filter that you put there or it's a special part to be use. If it's a special part that will be use for that purpose do you know what is the part number and the manufacturer, thank you.
Also i buy my fw-05rr conversion kit from rc-union and all was o.k.
Alain
Alain
#3847
Thats a Kyosho fuel filter, part #1876
#3848
Originally posted by Marcos.J
you beat me to it!!
you beat me to it!!
Rgds
#3849
Originally posted by TRAJ
I know you guys are probably SICK of this question but.....
I current own a V one RRR and i used to own a FW05R before that
I loved the FW05R and it run great
The V one RRR is abit taily But not uncontrolably taily
To those guys who own both the V one RRR and FW05R/FW05RR which car would you say is better on tire wear, setup ease?
Also if i run the FW05R/RR on a large track say with a 60metre straight, would the FW be able to to keep up with the belt cars if i install the Kawahara centre conversion?
I am thinking of changing back to the FW05R/RR
Thanks In Advance.
Thanks In Advance.
#3850
Anyone?
Anyone?
#3851
I have the FW05R, FW05RR and V1RRR and the RRR is better in my opinion. Perhaps due to its lighter weight, the RRR just carrys more corner speed. The FW05 can be faster if you have lots of traction but otherwise RRR works better for me. I think the FW drivetrain is so free that it pushes unless you apply brake. As such, the kit comes with 10,000 rear diff oil to help turn in but at the cost of on power steering. I also like the RRR's easy access to the pinions and spurs. It seems easier to maintain than the FW.
Don't get me wrong, the FW is still great and I am keeping both and racing both.
#3852
Thanks D i have pm'd him
#3853
what size track do you run on? small-medium? i am having trouble with my RRR. when i give it throttle it gets very taily and annoys me i have tried soft and hard springs less camber more camber but still same thing
any idea whats wrong with it? (sorry to be off topic)
#3854
HI thanks
HI thanks
It's hard for me to decipher why you are having problem with your RRR with limited info given, but my set up is close to stock and it works very well. I would first check if your rear diff is working right. It sounds like it's too stiff or locking up. If the rear diff case is damaged it could lock up the gears inside. Check if it's working properly. Also what tire size are you running on the RRR? The FW should use same size tire front and rear but you should run 2mm larger rear tire on the RRR. I also find that RRR works better with smaller tires (57mm front 59mm rear) where as the FW works better with slightly bigger tires (61mm front and rear).
#3855
Have you tried more toe-in the rear?
