Like Tree4Likes
Kyosho FW-05R
Old 10-20-2004, 02:58 AM
  #3256
Default Short track
Why is it that the fw05r is refered to as a good short track car?
Is the gearing too low for big tracks or the handling is better???
opposite lock is offline
Old 10-20-2004, 03:10 AM
  #3257
NiMo's Avatar
The FW05 is good on short tracks as it gets out of the corners.
As for large tracks, once you've fitted the 37T diff rings and a correct pipe (like the Kyosho) you will have plenty of speed.
Since I've fitted the Kyosho pipe I have been lowering the gearing as the car is now overgeared for a 155ft straight.
NiMo is offline
Old 10-20-2004, 04:04 AM
  #3258
TRAJ's Avatar
hey guys i was just wondering what would be better to buy for a medium-large size track
would it be better to get 37T steel ring gears or to get the kawahara centre conversion?
what would give me more top end?
and will i have to use 22/28 pinions with any of the two?
please help if you can
TRAJ is offline
Old 10-20-2004, 05:46 AM
  #3259
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
im using the kyosho pipe on my fw with 40t ring gears, and pinion combination of 21/51 and 27/45 and the car seems to have plenty of speed on a 210ft straight.
Marcos.J is offline
Old 10-20-2004, 05:53 AM
  #3260
TRAJ's Avatar
Thanks Marcos.J
i will get them
but what is the standard spurs on FW?
so that i can see if i have the ones required.
TRAJ is offline
Old 10-20-2004, 05:56 AM
  #3261
Bundy_Bear's Avatar
Trader Rating: 11 (100%+)
NiMo:
I have just finished reading this thread an i noticed when you first installed the RRR rear hubs you thought it made the rear unstable? How do you think the Fw05-RR will go then with these items standard for Rubber tyres?
BB
Bundy_Bear is offline
Old 10-20-2004, 06:12 AM
  #3262
Super Moderator
Marcos.J's Avatar
Thanks Marcos.J
i will get them
stock spur are 51/46
Marcos.J is offline
Old 10-20-2004, 06:27 AM
  #3263
NiMo's Avatar
Originally posted by Bundy_Bear
NiMo:
BB
The RRR rear hubs were unstable at first as it would not accept the set up I had for the original hubs, I have now found the setting and they are better, the only change I make to change from rubber to foam is to increase the camber from 1.5 degree to 3 degree.
The RRR front hubs are a must for rubber though as they allow more steering lock but does not throw the rear end.
NiMo is offline
Old 10-20-2004, 07:05 AM
  #3264
rjl
rjl's Avatar
Traj, I had the Kawahara conversion in at the Nats, 22-27 pinions are as big as you would ever need. I have tried a 28 but the car went no faster and the motor got very hot.
The big advantage with the Kawahara is the very slight overdrive, about 2mm split is all you need.
rjl is offline
Old 10-20-2004, 11:56 AM
  #3265
Racing4Evo's Avatar
The Kawahara is a little smoother than the 37T ring gears and the overdrive does help handling but there are not parts readily available if you break or lose something. That's why I chose the Kyosho 37T ring gears instead. Also, at the time, the Kyosho option was cheaper. I think the Kawahara conversion is $80 now.
Racing4Evo is offline
Old 10-20-2004, 02:02 PM
  #3266
NiMo's Avatar
I run the Kawahara option simply because the 37T Kyosho option wasn't even thought off, the 39T option had only just been announced by Kyosho but not yet released.
The wear rate of the Kawahara option is amazing, after 8 months the rear diff ring gear still looks like new, not even a wear mark.
NiMo is offline
Old 10-20-2004, 10:49 PM
  #3267
TRAJ's Avatar
Hi RJL thats the track im talking about Moorebank
so iff i get 22/27 pinions i wont need the 37T rings?
i have the 39T steel ones atm
TRAJ is offline
Old 10-20-2004, 11:44 PM
  #3268
Racing4Evo's Avatar
Originally posted by BrainTeased
does anyone here drive with a front solid diff ?
I'm going to try it out this Sunday(weather permitting). Totally different setup than before. I hope the new RRR parts are an improvement. I'm going to try just the front RRR hubs in morning practice and see how it goes from there, if I need more steering, I'll change out the rear end to the RRR hubs as well.
Old 10-21-2004, 02:50 AM
  #3269
BrainTeased's Avatar
Im gonna try it as well this weekend if weather permitts as well but the forecast says its a wet weekend for me. hope you get better luck!
BrainTeased is offline
Old 10-21-2004, 04:41 AM
  #3270
Super Moderator
Marcos.J's Avatar
i also going to test out the front RRR hubs ,i already ran the rear RRR this past weekend
Marcos.J is offline
