Kyosho FW-05R
#3046
Originally posted by NiMo
Check out some new models due for release soon.
Note : FW05RR
http://www.kyosho.co.jp/web/race/rac...eihin01-j.html
(translated from Japanese)
Further it is low center of gravity conversion and the NEW version appearance which carries out the optimization of suspension geometry! The shaft 4WD specification which fully loads the specifications in order to win with race/lace, aims toward worldwide game victory.
Note : FW05RR
#3047
RD Logic Championships
Originally posted by Racing4Evo
Congratulations to Marco Acosta for making the A-main at the RD Logic Championships in only his second race with the car. He was moving up the order when his rear driveshaft threw the pin and he lost rear wheel drive and brakes.
Thanks for pitting for me along w/ Ryan Namori. The car was very easy to drive in the main and was fast enough on the straight to keep up w/ most of the field. The car is getting better everytime I go out w/ the car. I am still trying to get used to driving a shaft car since all I've ever driven is belt cars. This car is very fast in the infield! Hey Peter, I have the motor ready for you
#3048
Nimo, since you have installed RRR front hubs, will it affect the toe in/out ?? And how much improvement in terms of handling for the car?
I am thinking of swapping my current ride for a FW05R
Thanks.
Thanks.
#3050
Took a look at my buddy's car, the tie rods seemed it can't be tightened anymore, unless it's cut??
Rgds
Rgds
#3051
Rgds
Rgds
#3052
Re: RD Logic Championships
I was hoping to pit for you, but I was a little busy
I will do that next time
#3053
Just a question, how competitive this car say comparing to the MTX 3? I have heard FW05R has less acceleration but its fast on technical circuits. I am contemplating a change
Rgds
Rgds
#3054
Thanks.
Thanks.
#3055
Rgds
Rgds
Tell that to the poor MTX guy I keep rear ending
#3056
Re: Diff advice for small track
Originally posted by i300i
I just received a 31582 hop-up FW-05R kit and will be asking a few questions. (Yes, I have read all 102 pages of this thread.)
I’ll be running rubber tires on a very small and tight prepared parking lot track; about 80 foot straight and lots of tight turns, with a few bumps.
Would it be easier to drive this style of track with a front differential, or with the one-way setup? If diff, would a lighter or heavier weight oil be better for this application? I'll be installing the RRR front hubs.
I've never driven with a front one-way diff, but I understand the trade-offs of each as far as loss of braking and gain of powering out of the turns. I don't mind a learning curve if it results in faster laps.
TIA
TIA
50k front diff, 10k rear
#3057
Re: Re: Diff advice for small track
You must have a front diff with rubber tyres (or spin out everywhere)
On a related note, I see that the foam tire kit uses rear dogbones that are a little longer (about 2mm) than the rubber tire kit. I don't see any other difference in the rear suspension exploded diagram (hubs or axles). Do you know why these parts are different and whether I'll need to use the shorter dogbones when running rubber tires?
#3058
Super Moderator
Re: Re: Re: Diff advice for small track
Thanks, NiMo.
Thanks, NiMo.
#3059
Re: Re: Re: Re: Diff advice for small track
Originally posted by Marcos.J
i think is because the rear foams are 30 mm in width and the rubber tires are 26mm
#3060
Thanks, NiMo.
Thanks, NiMo.
