Quick collet installation question
I just got a new collet for my flywheel. How do I install it? anything special I should know? Any dos/donts?
I just dont want to screw it up, seems like a fragile piece.
thanks.
thanks.
just slide it on..
if its a different length than than the old one, youll have to shim different...
Ill go try to put it on now, ill post again in about 15 mins on my progress.
collets dont usually go bad...
shims are the little thin washer looking things that keep your clutch bell from moving too much
as for the collet... I cant get it on.
Do you put the collet onto the shaft thingy, then put the flywheel over it?
Or do you put the collet into the flywheel, then slide it over the shaft?
is there any special tricks to doing it? heating up the collet or something maybe?
you got the old one off?
normally a lot harder than getting one on..
just push it on
just push it on
I heated it up with a propane torch, then pressed on it hard with a flathead screw driver.
Then I put the new collet into the flywheel, used tools and pressed real hard, now im having a hard time getting it onto the shaft thing that its supposed to go on.
If it just slips on real easy, whats stopping it from spinning freely like it did before (when it was shot) when my engine is screaming at 40,000 rpm?
thanks for the help imaxx, ill go try again, im just scared im gonna break something :s
the flywheel keeps it tight
take it out of the flywheel so it can open up and slide onto the shaft
never use tools to press anything ONTO your engine...
It slides onto the shaft fine, then getting the flywheel on is impossible, even when putting it in a clamp.
It slides into the flywheel fine, then not onto the shaft, not even 1mm, even with a clamp :s
Its impossible via hands... even with a clamp it didnt seem to make much progress, I didnt try very hard with a clamp as I was scared to bent/break something. Ill try to find a tut on google or youtube or something.
http://forums.radiocontrolzone.com/s...d.php?t=248191
hmmm, What if I put the collet into the flywheel, then snugged it up onto the shaft (it wont go over it, just bumps up against it), then tighetened my clutch nut, would that push the flywheel back onto where its supposed to go?
ps: what does this guy mean by "Also, don't use something in the glow plug hole to lock the crank, the force you will need will turn your rod into a micro-scale boomerang with ease...channel locks on the flywheel are a good idea."
when you say:
"It slides onto the shaft fine, then getting the flywheel on is impossible"
you mean its all the way to the engine??
if so leave it there, put the flywheel in the shaft and tighten the nut...
youll need to hold the flywheel with channel locks to get the nut tight is what he means...
the nut will force the flywheel onto the collet
the flywheel isnt just going to fit over it when its on the shaft
youll need to tighten the nut to push it back, cant do that with just your hands
when you say:
Ill go try the nut trick now.
sweet, I think I got it figured out, the clutch nut is super tight, the flywheel is pushed all the way back, I just hope I didnt bend/wreck anything in the process.
well have to wait till my clutch springs get here, then I can finish it and take it for a drive and see if it works, im 95% sure I installed it properly.
thanks a lot for the help imaxx
