HPI R40 Nitro Car Forum
#1098
I am going to have my R40 in about 3 hours, can't wait. I am also going to do a step by step picture build for some friends.
#1099
Looks like tower should have the light weight chassis in a few weeks, so hobby stores should be able to get them soon as well
http://www2.towerhobbies.com/cgi-bin...=++&search3=Go
#1100
Anyone have any build tips that might help? What oil is everyone running, and what oil does the kit include?
#1101
When building the 2 speed be sure that you have everything in the correct facing direction.
Also, make sure thers only a SLIVER of light able to be seen through the upper and lower 2 speed clutch shoes.
#1102
There's one tip I can think of.
Step 17 has you building the CVDs and installing them. After you are done, go ahead and put the wheel hex nut on before going on to step 18. This is because the pin holding the axle and dogbone together is captured by the bearing; there's no set screw holding it in place. The problem is, the pin can come out if the axle slides too far out of the bearing during the rest of the build.
#1103
Oh yeah watch that centax...
The thrust bearing in the centax clutch can be installed backwards. I know, I did it. It won't break anything and actually will still work backwards, but if you're like me, you want everything right.
In my kit, the thrust bearing and its' two washers were tied together with a thin wire. So when installing the thrust bearing, make sure the washer with the biggest hole goes in first (toward the engine).
#1104
#1105
Muwahahah. I got it and I am on step 3 hehe. I am having a little bit of trouble finding the ballcups that thread into the arms. anyone know where they are? I've been to spoiled by associated, now I can't find stuff...
#1106
Some guy in the factory probably has a big laugh each day about that.
#1107
yay, I found them. Now I'm on step 4
#1109
Regional Moderator
Yeah, HPI could have done a better job of bagging the stuff. It was pretty hit or miss trying to find stuff. But the "put everything into seperate bowls" method does help a little. But after building kits from many other manufacturers, I have come to expect the "one bag...one step" type of organization.
Thrust bearing
-I haven't installed my engine yet, so I hadn't messed with the thrust bearing yet. I noticed the thin wire on the thrust bearing, I assumed it was just there to keep everything together in the package. It is supposed to come off when I install the thrust bearing right? Atleast I would think so...
-I didn't even notice that the two washers had two different sized holes. I'll have to go back and take a look at it and see what you guys are talking about.
-Whats best for lubing the thrust bearing? I was going to use Associated 'black grease'........alot of it!
Thrust bearing
#1110
no wire..
The thrust bearing's are different(though you might need caliper to get it right)
black grease is fine..
