HPI R40 Nitro Car Forum >
Old 11-06-2005, 04:25 AM
  #9031
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Originally Posted by bummy
but i have never been able to get it into second.
any reason's why? or can sum one give me sum clutch specs so i can adjust it?
Make sure there is a hairline crack in the clutch shoes. Set adjustment screws on the sides to where they would almost get scraped. In just enough.
That should help.
Artificial-I is offline
Old 11-07-2005, 02:39 PM
  #9032
Rapid Roy's Avatar
also the tail end seems to be very slippery, does anyone have any sugestions to make it stick more, maybe iam using wrong diff oil? should i use grease what weight should i use.
my tyre choice is fast tyre's . great tyres/ but it just slides out so easy under power you give it a bit and it just spins around.
iam using the standard oil that comes with the kit, in that little bottle thing front and rear, i took the one way out, as the track i race on is very tight, and need full braking coming off the straight. cheers.
Use only the white grease that comes in the kit for the rear dif. The kit oil is too heavy.
Rapid Roy is offline
Old 11-07-2005, 11:23 PM
  #9033
Can anybodoy give me there droop setting for the R40 (Hudy gauges) front and rear
Brett
Brett.w is offline
Old 11-08-2005, 12:07 AM
  #9034
Chris West's Avatar
Hey Brett try 2 F, 5 R and 2F , 7R thats what I used when I had my R40
Chris West is offline
Old 11-08-2005, 12:46 AM
  #9035
Hi Chris
But how did you get the ride height needed with 7mm droop or were you not using the graphite upgrade rear shock parts? cause if i try 7mm all i can get is 3mm ride height without bending the arms
Brett.w is offline
Old 11-08-2005, 07:46 PM
  #9036
Greenbox's Avatar
Hara didnt enter his r40 into the ROAR nats cause of comitment of the Japanese ep touring car nationals. I wonder why they had to put both nationals on the same dates...I would've loved bragging rights of another ROAR win on the r40...oh well hopefully again next year. Winter project is some parts for the r40...Since i wont be able to run it much.
Greenbox is offline
Old 11-08-2005, 08:30 PM
  #9037
Chris West's Avatar
Originally Posted by Brett.w
Hi Chris
I used the +2 blocks on the rear and no graphite upgrade rear shock parts. I found the car went better on our track set like this.
Chris
Old 11-09-2005, 10:20 AM
  #9038
Greenbox's Avatar
Any one know where I can find some aluminum front body posts?
Greenbox is offline
Old 11-09-2005, 12:13 PM
  #9039
3racing makes some universal purple ones.
I got my new chassis in , going to weigh it tonight (standard process , lol). Im thinking on building up 3 different r40s. One a well hopped up 2004, my main race car. Then ill build the other 2 with the 3racing chassis and the one I just got and let them pit go again other and see which feels better for my backup. Maybe Ill find a winner out of the bunch .
Also has anyone tried the v2 shocks yet, Im ordering those next week.
Old 11-10-2005, 04:37 PM
  #9040
R40 Hara Edition in the US:
http://www.hpiracing.com/press/pr816.php
rossb is offline
Old 11-10-2005, 05:01 PM
  #9041
#816 Nitro R40 Hara Edition Kit w/o Body, Engine and Exhaust (WB255-260mm, 200mm, US SPEC)
EAN# 4944258008165
$799.00
Wow , wonder what the street price will be? Im guessing it will be $399 or so like the pro4?
Old 11-11-2005, 02:22 PM
  #9042
bummy's Avatar
will that make it less tail hapy if i use grease in rear end?
bummy is offline
Old 11-11-2005, 07:23 PM
  #9043
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
I still don't use grease in the rear of my R40 and it stays glued to the ground.
HarKonnenD is offline
Old 11-11-2005, 09:56 PM
  #9044
Does anybody have a set up for the R40 from the Worlds (Brasil) event?
Brett.w is offline
Old 11-11-2005, 10:00 PM
  #9045
MRX_joe21's Avatar
Contact hpi maybe they knows?
MRX_joe21 is offline
