HPI R40 Nitro Car Forum
#6346
That was me.
Bad thing was, I charged your car, but forgot to charge my own.
I have a 1400 mah battery but running 2 digital servo's killed me with 4 minutes to go, moving from 7th to 2nd position.
Hope you had a good time, and hope to see you at Superior for the points series starting next month?
#6348
I just went to my first Lakeland race last weekend. I've had a busy week. Went to Lakeland to race, then to Vegas for the NRHSA hobby show for our first time, then back for the HPI challenge.
I think I'm going to go to sleep for the next week now.
#6349
You can always find me at Superiors races, but I will be going to Lakeland more often now. I loved the track, fast but smooth. I'm usually running my Prospec on Full Throttle, and now Lakeland.
Do you know Abner, Austin and Bobby, from Melbourne?
#6350
Lookin for help getting my clutch adjusted properly.Motor reves
high on short throttle blips.Thanks in advance.
#6351
#6352
Any more details?
#6353
WHen I went to go break in my Rody V12, the engine revved VERY high as the adjuster nut was tightened down a bit. I added the last of the 6 shims and loosened the nut. The car rolled much faster and ran way better. Pretty much you'd want the CB to pull out very little. Maybe about a mm. Then the stock HPI adjuster nut settings will perform true.
#6354
Originally posted by JAG Racing
Man - did you use your teeth when cutting those shock access holes? j/k
#6356
Thanks for the info.Can anyone tell how many and where the shims should be?
#6357
Any of you guys have any info on the R40 2005 edition due to release in July?
#6358
Originally posted by Jea3
That was me.
That was me.
Sounds like youve been busy with racing. Good luck with everything. You were a really helpful.
Ill be there next month.
#6359
They will both be dubbed "HARA" Versions. And will be different and most likely better than the 2004 edition japanese kits.
#6360
what are the difference from the 2004 Hara Edition? 1 thing i know is that the main chassis will be the same and the fuel tank will be upgraded.
