HPI R40 Nitro Car Forum
#5521
Originally posted by KLANDERMAN
Hey you guys, while taking apart my WASP engine .12 turbo I noticed that it has 2 shims above the piston sleeve... If I remove one of thse would I get a more torquier engine or what happens?
I also noticed that my engine is a 3 port, with all that torque fighting against the OS .18tz I could have sworn this was a 5 port engine... oh well lol... I love this hobby!!!
#5523
Originally posted by Rapid Roy
Removing the shims will increase your compression. The only time you need to do this is when running different percentages of nitro.
#5525
Originally posted by HarKonnenD
Probably that or 30%.
#5526
Im having trouble putting my flywheel on my old motor. when i try to screw down the thing that holds the flywheel down all it does is turn the motor. The motor is a OS TR how can I hold the piston in place without damaging it?
#5527
I have a piston locking device that screws as if you where screwing the glowplug, so I start by doind that, but through the round port I place some cloth or a piece of T-shirt, so that the piston locking device isn't directly over the piston. That should hold the piston down, so you can tighten it right...
#5529
Ill try a piece of cloth.
#5530
1. make sure glow plug is installed and tight.
2. rotate engine leaving the exhaust port open.
3. holding engine upside down (heat sink down) fill with after run oil.
4. don't over do it you need just enough to hydrolock the piston not start an oil slick.
5. now crank down on the flywheel nut the oil will hold the piston stopping the engine from turning over.
6. now that it's tight remove the glow plug and drain the oil. OR simply reverse direction on the crank and drain via the exhaust port.
I've been using this method for years with no problems.
#5531
ok i'm getting a bit peeved at my clutch bell. I 'm having a heck of a time gettin the second pinion gear off.
Any one know any tricks to get these blasted things off without damaging the clutch bell?
#5533
nice ballfield needs a lil maitnance thou
LOL
LOL
#5535
hey hark waht did you use to get your pinions off the clutch bell?
