HPI R40 Nitro Car Forum
#2281
Originally posted by burger
I keep seeing people mention the 22t pulley. I guess this would replace the 21t front pulley for the mid-belt and overdrive the car a little. Is this only for a one-way setup, or can it be used for the front gear diff setup too?
#2282
Regional Moderator
Originally posted by luchinlb
People i still have problems deciding which equipment i should get.
I want Mid range stuff. Nut too expensive but not that sheap.
Can you guys give options (Brands, models and price) of a good:
Strater Box
Glow plug ignitor
Engine
Radio Equipment
Please help me out here...I´m starting on this hobbie and i want to be on the track ASAP.
TIA
Strater Box
Glow plug ignitor
Engine
Radio Equipment
TIA
Glow plug ignitor- the above box comes with a ignitor that plugs into the power panel. Never worry about whether your ignitor is charged.
Engine- I had great success with my OS .12 TR last year, and have gotten a great start with my Sirio 12 TRP this year. I've also seen the Sirio 12 EVO2 run up close this year and its quite impressive. The OS .12 TR is about $110 these days, and both Sirio's are about $160 these days.
Pipe and manifold- You didn't mention this, but you'll need one! I use Trinity's one piece pipe set. There are lots of choices out there though. I prefer the one-piece units though.
Radio- Any FM radio with things like end point adjustments, dual rate, and maybe synthesized channels so you wont have to buy any extra crystals.
These are just suggestions, but hopefully they'll give you somewhere to start. Good luck.
#2283
Originally posted by AMGRacer
I also have a D3 and I am not really having that bad of a time with it. I have adjusted the carb and nicely and the exhaust clears the belt pretty comfortably. Just crank down on the belt tensioner, the belt will still run nice and free.
The hardest part is definately getting the motor in and out for sure.
Pulling the motor with the side brace off is easy enough for me.
#2285
I checked the D3 and compared it to my old Novarossi SX12 RE and it really does mount lower in the car. Almost a full 1/8"! I made the spacers last night and raised the motor 3/32" and it is perfect. The belt tension is right where I want it and not touching the exhaust, and the carb clears the tank mount much better. Before, the flywheel was about level with the bottom of the chassis, now it has a little more clearance.
#2286
Originally posted by 20 SMOKE
does anyone think any of the parts for the 2004 spec will fit the old car. saw a pic of it and a new top plate that goes over the front bulkhead looks like a mugen top plate
#2288
The radio plates doesnt go over the front bulkhead. The picture he posted was the MTX3 Pro Spec.
#2290
#2292
guess thats what happens when the brains going faster than the eyes, stop look close than speek
#2293
Well that is pretty nice Mine fits in there pretty well without the mods however, I will try and get a picture this weekend. You run the D3 yet? Man that badboy requires some serious breakin.............
I'm really looking forward to seeing how well it runs. It's just now the beginning of Spring here, so the first warm day we get I'll fire it up.
#2294
Nope, haven't run it yet. I need to get a gallon of 16% with high oil content for the break-in. All I have is 20% O'Donnell.
#2295
Super Moderator
go to the mtx vs r40 marcos posted it
http://cgi.ebay.com/ws/eBayISAPI.dll...category=44015
