HPI R40 Nitro Car Forum
#151
jhigga15: Shock towers are aluminum. Carbon fiber towers are optional.
Definetly looking forward to hearing reports from people that have this car as to how well it works.
Later,
Later,
#152
they are aluminum? i thought they were plastic
#153
The stock shock towers are aluminum. Woven graphite shock towers are being developed and were used this past weekend. The rear shock tower includes a graphite mount that attaches to the suspension arm (in the stock shock mount holes) to relocate the bottom shock hole to take advantage of an improved shock stroke.
#154
Originally posted by Pit-racer
Yes, the tanks seem to hold less than is the roar legal limit.How do I know ..... I was there when they were being teched. About 3 cc's less than others.I was at the nats. in calif.
frank,can you get thad to comment on this?..
#155
#156
car looks good but its a heavyweight... can it handle more abuse then? ... i wonder if this car can perform in the parkin lots?
#157
Haven't seen you at the forum for quite some time. Got any car yet? Well, for the HPI R40, I'm sure you can run it in the parking lot, just like any other great cars.
Why would you want to abuse your car, though?
Wouldn't you want to learn how to drive and be good at it?
$0.02
#158
Originally posted by eddiethefish
hi cHckbOY5,
$0.02
hi cHckbOY5,
$0.02
#159
Originally posted by Vinyard
I learnt thru abusing!
#160
Originally posted by Manbik
The winning setup
The winning setup
So it comes with two-gear diffs?
#161
it's 4 gears
#162
The 4 gear diff worked better for looser conditions. Basically, a diff with 4 gears has more mechanical friction. So if you use 30,000 with 4 gears it will feel similar to a two gear diff with 50,000. Also 4 gears vs. 2 will have slightly different characteristic on and off power. It’s definitely something to try. I think the stock two gear diff with 50,000 will work best for most people who don’t have laser precision throttle control like Hara.
#163
#165
Originally posted by jbackslash
it's 4 gears
it's 4 gears
I'm not counting the outdrive gears.
