HPI R40 Nitro Car Forum >
Old 02-02-2004, 06:11 PM
  #1546
Fatboy Joe's Avatar
Originally posted by fastharry
The tank is a shade smaller than 75 cc's....(about 72)..HPI is redisigning the tank......
Thanks fastharry, btw, how long should my fuel line be just to make up for the 3cc? Or can I just get a slightly bigger fuel filter like what hara put in his car?
Btw, I joined a race last sunday and I came in last. My wheel came of bec I didn't tighten it well and I bent my stinger and cracked my pipe. It took a while before I can get restarted but once I got back on the track, I drove the R40 like there was no tommorow. Yes, I still got last, around 12 laps down but that was due to my mishaps but man, I tried driving it to the limit and I was really wishing that my car didn't break because I know I'd be on the podium somewhere bec no matter what I do to the R40, it still remained stable, hooked and consistent.
Here's what I have so far in my R40:
1. Lightweight mid shaft
2. Lightweight 2speed shaft
3. Lightweight chassis
4. Carbon Fiber Front Shock tower
5. Carbon Fiber Rear Shock tower
6. Rear Blade Type swaybar
All I need now are:
1. Titanium screws
2. Lightweight 2 speed
3. Aluminum Hex hubs
4. Bigger tank (if there is any)
5. A more powerful engine
Fatboy Joe is offline
Old 02-02-2004, 06:55 PM
  #1547
OZDC's Avatar
Trader Rating: 16 (100%+)
Originally posted by AMGRacer
That works out to around 5cc a lap, so 3cc is almost 1 lap earlier on refueling.
When you put it that way............maybe no so trivial an issue.
DC
OZDC is offline
Old 02-02-2004, 07:20 PM
  #1548
AMGRacer's Avatar
Around 8 inches of line for 1cc. Fuel filter probably 1-2cc never measured this one. Problem you will have is that if you have used the tank (run it dry) and you are actually running on the fuel in the line (quite possible with a very long line and filter) when your pitman fills your tank you will end up with a huge airbubble in the line since the tank fills but not the fuel system.
What do you think of the rear blade swaybar? Did you notice that it is much stiffer than the wire? How do you like how it mounts? I am unsure of the way HPI designed the mounting, seems a little off.
Did you weigh the light chassis vs the stock chassis?
AMGRacer is offline
Old 02-03-2004, 01:52 AM
  #1549
Fatboy Joe's Avatar
Thanks for the info on the fuel line. I like the blade type swaybar due to it's adjustability. With the wire type, you need a couple to fine tune, while with this one, just turn the blade to different angles until you reach your desired setting. The mounting is pretty mnuch straight forward. I was not able to weigh the diffrence of the stock vs mod chassis but just by holding it side by side, you can notice a big difference. I did not bother putting on the stock chassis anymore, you really notice the weight.
Old 02-03-2004, 04:36 AM
  #1550
fastharry™'s Avatar
hey Joe..you have the HPI chassis,right?..
fastharry™ is offline
Old 02-03-2004, 08:08 AM
  #1551
Chewdogg's Avatar
how much more tension?
I went up one notch from stock. The rear middle pulley (that turns the rear diff) seems to last a lot longer once I increased the tension.
Chewdogg is offline
Old 02-03-2004, 08:23 AM
  #1552
rod_b's Avatar
I don't know what the exact difference is but you can easily tell just by holding both in your hands.
Has anyone tried the 22T front pulley and if so, how much split did you run between the front and rear tires?
rod_b is offline
Old 02-03-2004, 10:00 AM
  #1553
Tech Prophet
InitialD's Avatar
About 3 mm split should be fine.
InitialD is offline
Old 02-03-2004, 02:22 PM
  #1554
AMGRacer's Avatar
The front internal ratio with the 23T side pulley is 2.42105 (pretty sure! don't have the car here) and the 22T side pulley is 2.31578. This works out to be a 4.5% overdrive situation.
It seems that the split should be around 3mm like D said to keep a 1:1 front/rear ratio.
AMGRacer is offline
Old 02-03-2004, 05:58 PM
  #1555
fastharry™'s Avatar
HPI says the chassis is 20 grams lighter...
Old 02-03-2004, 06:22 PM
  #1556
AMGRacer's Avatar
Their website says 20%: http://www.hpiracing.co.jp/contents_...up_e/0311.html
But that may actually equate to 20g
AMGRacer is offline
Old 02-03-2004, 08:12 PM
  #1557
fastharry™'s Avatar
HPI Racing is proud to announce the release of our newest option part for the R40 Nitro pro racing car: the Light Weight Super Chassis! Machined out of aerospace quality 7075S aluminum, this chassis is 3mm thick for extra strength and stiffness. Many areas of the chassis are milled out to reduce the weight without sacrificing strength, and the cutouts in the chassis are enlarged from the stock chassis. The underside is also beveled on both sides to reduce the chances of the chassis touching the ground in hard cornering maneuvers. To enhance engine cooling, an angled air opening under the motor is cut out to increas the amount of air flowing past the engine! All this adds up to a chassis that is stiffer than the stock version and 20 grams lighter! No racer will want to be without this excellent addition to the R40 option parts line.
Ye of little faith.. (of course,maybe they[HPI USA] lost something in the translation.......)..
As long as its lighter,its good enough for me.......
RACE ON!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 02-03-2004, 08:40 PM
  #1558
tranced's Avatar
Sorry to burst your bubble, but this was released approx. 1 month ago
*snip*
tranced is offline
Old 02-04-2004, 02:08 AM
  #1559
HPIRACER310's Avatar
Thanks for the info on the chassis
any news on an HPI or aftermarket hop-up for the steering servo guard?
HPIRACER310 is offline
Old 02-04-2004, 04:37 AM
  #1560
fastharry™'s Avatar
i knew that..just wanted to point out the USA translation of the weight savings....
