TQ Racing SX8
#1081
Rebound is the amount that the shock shafts comes back out after it has been compressed all the way up...You can set the amount of rebound in the shock by the way you build them,It just depends on where you set the shaft in the body before you tighten down the shock cap..
#1083
bernie too much oil
#1085
Start by filling your shocks up with oil,then bleed all of the air out(like you normally do).If you leave the piston all the way at bottom of the shock you should have full rebound.If you push the piston half way up in the body the shaft will rebound half way back out/down,etc.Building your shocks with full,half,quarter,or no rebound will make your car handle differently.You'll just have to play with it to get the fill your looking for..
#1088
I use the Sportwerks tool to remove the shoes and use a strait screw driver to install them back on.
If you run the alum shoes be sure to run 2 thin washers behind the shoes.
Shocks; I run 1/4 rebound.
Marry X-MAS to all.
Marry X-MAS to all.
#1089
Brian ygpm
#1090
When would you like me to call you?
#1092
Thanks Curt, I am going to start with full rebound and work my way down.Also did the changes that you made lp last week at crcrc. Thanks and merry christmas.
#1094
Luther or anyone that knows or team drivers. Is TQ racing open tommorrow? I need one part to get the car running.
On the big bore shocks the lower cap that holds the o-rings and spacers was left out of the kit. 3 of the 4 shocks had them, but one was left out.
Does anyone have one they can overnight me or if TQ will be open tommorrow I can get them to get me one. I wanted to get some first practice in this weekend with the new car. If anyone can help please let me know. I will pay for everything.
Thanks,
Shannon
[email protected]
Thanks,
Shannon
[email protected]
#1095
Please disregard previous post. Big thanks to CHILL WILL for hooking me up with the part I need. You da man!
