TQ Racing SX8
#364
Mine was 45.66 and 45.74, the replacements I had from King Headz were either 1-2mm longer, the Kyosho style from King Headz. Got them for my last buggy and never installed em. No shims, just bearings and king headz steering posts.
#365
Looks like Easton is gonna put the car in the main at the manufactures cup!!!
Any more info?? or updates?
#368
Mine weighs about 7 pounds 8 ounces dirty.
#369
My front diff started leaking, do you guys know if Kyosho diff o rings will fit? I just happen to have some and would save me from ordering some. Thanks!
#370
http://tkocompetitiondev.com/shop/in...p?cPath=38_114
http://www.amainhobbies.com/product_...ducts_id/25728
#371
Diff building tutorial....
http://www.unlimitedengineering.com/...ad.php?t=19076
Very good info there ^^^
PS- Nice avatar JP :P
#372
NitroOB4You,
I see on your advert your using a Nomadio React, does your radio box close properly, mine has a small gap, not completely dust proof. I have tried with/without foam padding on the bottom, have you taken the foam padding out?
I've tried both methods it’s a very snug fit, due to the size of the transceiver. Any tips would be greatly appreciated.
#373
I havn't had any problems with mine, so far. Though I do wish they would return and release that mini/micro Rx they talked about a while back.
I'm also running an Apogee 2000Mah LiPo, with the regulator on top of the Rx. I can try and get a pic or two later today or tomorrow.
#374
#375
My box is the same. I over stuff it with foam to seal good.or you can run a bead of rtv around the edge.
