TRF414M, 404x, 414, 414X
#3571
Guys,
I am looking for the 414 steering posts and carbon upper deck (for the first 414 model).
Hopefully someone can help me out.
Cheers,
Eric
Cheers,
Eric
#3572
Hi Guys,
Would the 419x belts (171/61) be too loose for the 414M (169/59)?
Thanks.
Joel
Thanks.
Joel
#3573
Might work if you use the belt tensioners. they are approx 6mm longer so that is quite a bit regarding the actual tension of the belts
#3574
I'm looking for trf 414m2 bulkhead beam. Anyone have it please let me know.
Palm
Palm
#3575
Many new and used part for sale for the TRF414M
#3579
#3582
#3583
#3584
I just finished fitting the front and rear shock towers with my TRF419X towers along with big bore short shocks and aluminum battery straps.
The only thing original from the TRF414 is the light weight front and rear bulk heads, light weight motor mount, spur gear holder and shaft.
Post any questions or if you want me to post a closer picture of and area, let me know
#3585
I am not 100% on the steering. I have so many different configuration in stock trough out the years. I think its TRF415 shimmed up high enough where it would clear the front belt when sweeping. The rear gear diff is from a Yokomo BD7 2016. The front spool is also from the Yokomo BD7 2016
I like the shock towers
