TRF414M, 404x, 414, 414X
#2521
Calvin...
that's good to know. Good thing I didn't chop up a good TAMIYA heat sink, haha.
I have no clue about anything on brushless.
#2522
thats ok im sure its ok to run a motor cooler then it is
#2523
Hi,
First of all, the TA04 WC bar does not come with SSG but black carbon. I know because I have one... The SSG is just for the TA04 TRF kit.
Second, concerning the fan, you should definitely move it from there. Indeed, the best place to put it is blowing on the endbell, because the hottest part of the motor is the interface between the brushes and the comm.
Thus you want the brushes to keep as cool as possible, in order first to keep a good efficiency during the heat, and second to increase their lifetime. My fan blows directly on the endbell and this just works the best, you should do it.
Anyway, is the 414 dead ? Nooooooooooo !
#2524
no the 414 isnt dead ok
alot of the people are moving to evo 3's and stuff but then some moving back
and plus tamiya ditched to car so its kinda dead there. because the the designer moving etc. etc. etc.
#2525
I've had 2 EVO3's and still went back to my 414M
Cobra....
The fan on my 414M is pulling the air out, not into the motor. And putting the fan at the endbell area it makes it a hassle to take the motor in and out. Works great for the endbell on my EVO though.
Cobra....
#2526
no fan is always better then having a fan
do you put the fan wires on the motor so when you press the gas the fan also goes or directly to the batteries?
#2527
never plug it to the motor, they're b/l motors that doesn't like changing revs. Plus, you want your motor to be as cool as possible, then why don't blow at it even off power ?
A fan doesn't uses that much current (something like 50 mA in 5 minutes, nothing compared to the 3300's we have now).
Suradaj : yup it's a hassle, but I was fiwing it with dble sided tape, which is not very secure, but did not have any pb. If yours is taking the air out of inside the can, then it's not that bad, and much more secure...
#2528
thanx a bunch!
#2529
I did not put the fan wires onto the motor. It's pluged into the Rx. So when I turn the car on, the fan also goes on and it stays on until I turn the car off. I didn't notice any loss in battery with this fan. It suck up very little juice like Cobra had mentioned.
#2530
sweeet
i would like to plug it into the rx too except its tooken by the transponder
#2531
I have the new Rx that came with the KO Helios so it has 4 slots.
#2532
thats alot better. my airtronics one doesnt the blue one
#2534
your joking!!!!!
noooooo
noooooo
#2535
i hope they make it so it has 414 can be upgraded to the 415
u sure about this
i hope it never comes out it'll make me spend more money AGAIN!
u sure about this
