What Tires You Use? >
What Tires You Use?
What Tires You Use?
Old 07-26-2003, 09:49 AM
Default What Tires You Use?
hey was just wondering what tires majority of the people here use...
simply state
Tire Type, Make & Model?
Inserts ?
Surface ?
Comments ?
might more or less tell us whats the favourite brand is for different surface.. could be helpful!
versa is offline
Old 07-26-2003, 10:42 AM
CGR
CGR's Avatar
Asfault - Sorex 36-40
CGR is offline
Old 07-26-2003, 10:43 AM
mainracer's Avatar
Take off cs 22 or 27
mainracer is offline
Old 07-26-2003, 11:39 AM
You can't go wrong with Sorex 36,32, and 28's. It all depends on the heat of the track!
Tom M is offline
Old 07-26-2003, 11:50 AM
Asphalt - Sorex 36R, 32R, 28R with Sorex Medium/Firm A/B inserts.
Carpet - Sorex 28R, 24R, 20R with Sorex Medium/Firm A/B inserts. Hpi Red also works good.
James Nguyen is offline
Old 07-26-2003, 12:18 PM
popsracer's Avatar
Default What Tires Do YOU Use?
After much experimentation running both Electric and Nitro, here are my thoughts.
Sorex's:
Like SMOOTH Asphalt best (slurry coated/sealed), not for concrete. 36R's provide the best grip in the widest temperature range, my prefered (rubber) tire for Nitro on Asphalt.
Take-Off's;
Work good on just about all surfaces. Best all around tire for Concrete. My Tire of choice for Electric. All compounds work in a wide temperature range. Bargan price for assembled sets.
Yokomo's
138G's (S,F,H) work best on ROUGH Asphalt, with the "F" and "H" compounds being best for Nitro. NOT for SMOOTH Asphalt or Concrete.
HPI inserts work well in all the above Tires and have 5 different firmness ratings to choose from, with Red and Green being the most popular.
Yokomo inserts offer slightly more Air-Gap and have 3 types availible.
popsracer is offline
Old 07-26-2003, 01:25 PM
I use Take-Off 27's for indoor carpet on my TC3. They seem to hook up pretty well and they last a long time. They are also pretty cheep for a set of 4 preglued tires, you can get them from KT Hobbies for 28 dollars or something.
racerdx6 is offline
Old 07-26-2003, 03:44 PM
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: What Tires You Use?
simply state
Inserts ?
Surface ?
Comments ?
Sorex 32R & 36R on Asphalt
Xenon X type Black(med) or X type Blue( firm )
High Bite Asphalt
I can get away with using only these two tyre types and inserts at almost amy track can still get great wear on then tires all year round
JDM_DOHC_SiR is offline
Old 07-26-2003, 05:59 PM
dtm
dtm's Avatar
Sorex 36R and 40R..
Sorex Type C inserts (Med or Hard)..
High bite Asphalt
The 40R wear quicker than the 36R strangley enough!
dtm is offline
Old 07-26-2003, 06:12 PM
StephenSobottka's Avatar
I use TO 27 premounts on my car indoors on carpet. seem to work good on every surafe i have raced though.
StephenSobottka is offline
Old 07-26-2003, 08:52 PM
I forgot to mention that the Take-Off tires work great on almost any surface though. But the only thing you might change is the compound if you're outside and it starts to get really hot. Than you might try a 32 or something. But 27 is a pretty good starting point.
racerdx6 is offline
Old 07-28-2003, 12:14 AM
analyzer's Avatar
sorex 36R
analyzer is offline
Old 07-28-2003, 01:08 AM
take offs, cs-27s ... cheap and good
Johnnytc3 is offline
Old 07-28-2003, 04:13 AM
hey one question.. i've been looking around and i noticed that some places sell their inserts/rims/rubbers by pair and some sell it by a set - 4 pcs..and some just dont mention the price is for pair or set
i looked at speedtechrc and they didnt mention whether its a pair or a set..
so how would i know how many im buying? geez how do they do business
versa is offline
Old 07-28-2003, 04:48 AM
i wish there was a control tire regulation at my local track. i dont see it fair to see some guys with fat wallet burning a new set of rubber every run. and some even buy at least 10 sets of tires when new stock of tires arrive, completely cleaning up the shelf and leave most of us nothing.
what would you do if you're faced with that kinda situation ?
sebastian is offline
