RC Planet XENON Cup 2008
Date : 1st June 2008 (Sunday)
Venue : Planet Speedway
Time : 7 a.m.
Participants : 50
1. Entrance Fees:
2. Lucky Draw Prizes & Trophy:
Race Categories:
1/10 EP Car Touring 23T Stock
3. Layout:
• Layout change will be done 2 weeks before race day -18th May 2008.
4. Rules & Regulations:
Technical Inspection
• All cars must be presented for Technical Inspection immediately after completing every ‘Heat’ and ‘Final’.
• ‘DO NOT’ take the cars to the pit area before the inspection.
Car Brand
• Open to all brands
Battery
• Batteries: Ni-Mh Maximum spec - 7.2V / 4600mAh
Li-Po Maximum spec – 7.4V / 5000mAh
Motor
• Only one (1) official Xenon Motor with an authorized label/mark provided by the organizer is allowed.
• If motor provided is burnt or damaged in any way during the race, the driver will be disqualified from the race. No exception!
Car Body Shell
• 4 door 1/10th Scale touring body shell
• Body shells may not be cut above the door line & bumper line of the manufacturers molded line.
• All wheel arches must be cut out
• Wing
Wing or spoiler can be used on the rear of the car. (No front wing)
Dimension: Maximum wing chord - 40mm
Maximum wing width - 190mm
Maximum wing end plates - 40 x 20mm
• Wing or spoiler must not overhang more than 10mm at the rear of the body
• Only one wing is allowed per one body shell.
• The standard body wings and spoilers can be used. Optional wings are allowed as long as they meet the requirements.
• Car Dimensions :
Maximum width without body - 190mm
Maximum width with body - 195mm
Maximum wheelbase - 270mm
Minimum height - 115mm
• Weight: Minimum weight 1500 grams including transponder.
Tire Ruling
• Only Rubber tires are allowed.
• Tire must be XENON rubber tire, XENON insert & XENON rim
• Tires will be scrutinized and marked.
• Control Practice – tire, insert & rim open, no marking required
• Pre-Qualifying – tire, insert & rim control, no marking required -- CANCELLED
• Qualifying and Finals – 2 sets of 4 tires only
• Final A Main – Option is given to the driver to use another set of tire
Penalties & Disqualification
• 10 second stop go penalty for the followings:
i. Dangerous driving.
ii. Consistently blocking of leading cars during qualifying. (After 1 warning has been issued).
iii. Deliberately hitting other cars.
iv. Driver must at least drive through the pit lane at most 1 lap after official announcement. Meaning once the penalty announcement is made, driver is allowed another lap before pulling in for stop and go penalty. If drivers fail to pull in for the penalty, 60 seconds will be added to the heat or final he is currently running.
• Add 10 sec penalty to the best time for the following:
i. Misconduct and unsporting behavior during the race. This shall include improper language and/or other demeaning actions. This is subject to the discretion of the Race Director. The Race Director decision is final.
ii. Failure to perform marshalling duty.
Marshalling
• All drivers must perform marshalling duties. Drivers who fail to perform the duty will have 2 laps deducted from the best ‘Qualifying’ run or ‘Main’. It is the driver’s responsibility to find a substitute marshal. The original marshal is responsible for the actions of the substitute.
• Marshals must not abandon their post to get a car to a pitman for repairs. Marshals will take disabled vehicles to the closest outer edge of the race track as soon as possible. Vehicles still racing has priority over handling of disabled vehicles.
• During marshalling, marshals are not allowed to smoke, communicate with any communication device and doing any activity that might disrupt the race.
• All marshals must wear proper attire and no slippers (only closed toe footwear) allowed during marshalling.
• All marshals will be assigned a specific location to perform his/her duty.
5. Race Formats:
• Control Practice - 10 minutes for each group
• Pre-Qualifying – 3 minutes for each group -- CANCELLED
• Qualifying & Finals – 5 minutes for each group
• Best Heat System - 3 heats (5 minutes per heat)
• 3 finals for “A” Main will be based on best 2 combine point system
• 2 finals for “B” Main will be based on combine point system
• 1 final for “C” Main onwards
Register yourself to and sumbit payment to:
RC Planet Sdn Bhd @ Planet Speedway SS19
Rudy or Uncle Simon - 03 5636 5163
or you can direct bank in cash to:
Bank Name: Alliance Bank
Payee: RC Planet Sdn. Bhd.
Account Number: 12015-0-01-007446-4
Please FAX the bank-in slip with your good name on it to 03-56365163 as a proof of payment.
Thank you!
1/10 EP Stock
Name / Freq / PT# / Contact #
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
1/10 EP Stock
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
way to go gwen...
1/10 EP Stock
Name / Car / Freq / PT# / Contact #
1. Jason Hee / Xray T2 '008 / 40.845 / 012-2786303
2.
3.
4.
5.
6.
7.
8.
9.
10.
1/10 EP Stock
2.
3.
4.
5.
6.
7.
8.
9.
10.
Rudy...
Pls register me for the race. I'll drop by later to pay the reg fee .
Shahrin / XRAY T2'008 / DSSS / 012-377 0273
1/10 EP Stock
2. Andre Tew / Xray T2'008 / 2.4Ghz / PT 5233003
3. Shahrin / XRAY T2'008 / DSSS / 012-377 0273
4. Akmal / XRAY T2'008 / 40.815 / 012-684 7064
5. Sani / XRAY T2'008 / DSSS / 012-927 1116
6. Airman / XRAY T2'007 / DSSS / 012-368 8399
7.
8.
9.
10.
1/10 EP Stock
7.
8.
9.
10.
