Lipo Charger question
Trader Rating: 32 (100%+)
Has anyone used one of these yet?? http://www.horizonhobby.com/Products...rodID=LOSB9607
and if so how well does it or doesnt it work?
What is everyones perfered Charger that charges atleast 10amps?
Just my thought, but before I invest another 35.00, I will be looking for smaller chargers with built in balancing... Since the airline lines are going to charge me 25.00 more for a second bag, I want be able to travel with small equipment... Need to make room for my shorts and shirts...
I know that Core has a new charger/balancer which is getting great reviews.
Yeah i was looking for something small as well that will go up to 10amps....the Core charger only goes up to 5amps...they are nice and priced right.
Maybe something like this is better yet???
http://www.horizonhobby.com/Products...?ProdID=THP610
Is this charger a knock off of another charger on the market that Thunder Power slapped its name on?
Kevin,
That is the thunder power 610. It is a great charger with built in balancer. I just bought one and a buddy of mine has one too. They are nice!
+1 for the Thunder Power 610C. picked one up late last week, it's a great charger. love the size too - compact.
From what I’m told a higher rate just charges faster correct? And from what I can gather is needed some times depending on how much time you have and how much you take out of the pack? Plus from what people are saying a higher rate of charge is making the packs run faster...getting them hotter? If none of this is true then I guess I don’t need a 10 amp charge....but I would rather have a charger that can go that high and turn it down then one that doesn’t and have to buy another one later.
If you are charging nimh batteries then the highest most people charge is 5-6 amps. Thats only done in stock or 19 turn, because it lowers capacity. Mod guy chage at 4-5 amps. Nimh do run best when warm from a freash peak charge. Lipo is totally different. You do not want them to feel warm. That means a possible fire or explosion. The charge rate for lipo is measured as 1c. Which means for every 1000mah of capacity, the charger charges at 1 amp. So a 5000mah pack would charge at 5 amps.
over charging your lipo packs is a big no no. it doesnt give you any additional run time, or better voltage. what over charging does do is shorten the life of the battery, and could be very dangerous. it could cause the battery to fail, would would then cause it to cath on fire.
