Tekin RS ESC sensored
65 feet
Thanks for the help its about 20 meters or 65 feet so i supose its a small track to you guys i have the tekin rs pro with the lrp x12 13.5 running at 7.2 fdr the car is fast with lots of grunt and top speed i have had the delay set from 0.1 up to 0.5 hope you can help and thanks again
boost 40
turbo 15
4 dot insert
delay 0.2
start 5000
end 20000
turbo ramp 2.0
boost 40
turbo 15
4 dot insert
delay 0.2
start 5000
end 20000
turbo ramp 2.0
I'd flag the turbo on a track that small. Turbo was originally intended for large straights. With yoiur end timing at 20,000, you will be getting the turbo trying to kick in before all of your boost turbo is in.
Try and bin the turbo, and have your end timing at about 16,000 to 18,000, more punch that way
ok mate thanks for the help what size track would you use the turbo on and would you say my fdr is ok also do you know anything about 208 fw
also what motor would you recommend to use i have the tekin 13.5 and sp v3 lrp x12 thanks again almost forgot the i have the new gm to
turbo on a track 100ft and up.try the 7.2 fdr since you are using turbo now and may go to a 8.0,turn tturbo off and bring the end rpm down a little no more than 15k end rpm,and i run the redlines so me personaly i stick to it
hello 20 smoke
thanks i will try this at my next meeting will also fit the tekin motor back in. what motor timing and boost should i start with?
How soon will we see an update for the new ROAR 17.5 rules or will there be one specifically for that?
