Tekin RS ESC sensored >
Old 05-04-2010, 08:05 PM
  #14386
Trader Rating: 66 (100%+)
Default Question
I have a question that may have been answered already. I have a cyclone tc geared at 5.94. I recently swapped my lrp spx for the tekin rs with the 2.03 software. I have ran my car twice with the tekin rs and during a 17.5 race I blew up my thunder power 40c lipo. I thought it was just the pack so i then ran a 40c smc pack and that one blew up too. My LHS setup my tekin for me with a conservative setup. I just checked my charger (onyx 230) and it was charging lipos just fine. I was checking the charger with a voltmeter and everything was working great. Has anyone encountered this problem before? If you have any trouble shooting ideas please let me know. I am beginning to think i have a bad tekin.
goose510 is offline
Old 05-04-2010, 08:24 PM
  #14387
L.Fairtrace's Avatar
Trader Rating: 24 (100%+)
I'm no expert in electronics but I cant imagine how a tekin bad or otherwise could blow up 2 battery packs with a 17.5
L.Fairtrace is offline
Old 05-04-2010, 08:37 PM
  #14388
Trader Rating: 16 (100%+)
Hi goose,
First question...Do you know what that "conservative setup" actually is...settings wise?
Best guess is...Considering that others set your RS, what is your Voltage Cutoff setting? Being set to lower than "2" could easily kill your 2S lipos by allowing extended duration runs resulting in too low of voltages (sub 6V) on your packs.
Bill
Still Bill is offline
Old 05-04-2010, 09:07 PM
  #14389
Originally Posted by Tubaboy
No they don't. Loosen the 3 screws, and use a flat bladed driver to push the timing ring marker to the edge of the C solder post on the motor. That will give you more timing.
Originally Posted by 20 SMOKE
forcing some thing that was not suposed to move
I asked Novak support about the timing on a 13.5 SS Pro.
Guess its the same for the 17.5
Thought Id share the response with you:
  • The factory timing is set to 30 degrees.
  • To change the timing, you will need to loosen the three screws on the back plate and then rotate the orange colored ring clockwise to retard and counter-clockwise to advance. I would recommend not going farther than 3 or 4 mm in either direction.
  • 15 degrees is the lowest recommended timing.
  • 45 degrees is the highest recommended timing.
My understanding is that less timing will give more torque at low rpms and produce less heat. Thats why it seems logical to me to set the can timing as low as possible. But looking at the SS and seeing no indication what timing is actually set, Im probably not going to muck around with it and just leave it where it is.
The recommendation of the LHS guy who sold me that combo (because he didnt get any Tekin 13.5 for months) was to crank up timing and turbo in the RS to max and adjust the gearing accordingly. Reading the forums here I figure that thats probably too much timing if the can has 30* already.
I guess my next motor will be a Tekin..
DrBen is offline
Old 05-04-2010, 09:15 PM
  #14390
bradchurch123's Avatar
Default gjrcc.org
Originally Posted by TeamTekin
Yes the RSpro will sell for $200 plus. It has a massive pile of 48 fets compared to 24 in most controllers that have a heat sink and need a fan. Small and that much raw power handling does not come cheap.
Most spend hundreds on tires, batteries, bodies, entry fees, travel, etc... Why bargain shop on the most important part of the system and something that will likely outlast the car it is in? Power is nothing without control, feel, adjustability and durability.
The 24 fet RS will sell for less and handles most applications to a 5 turn motor. We have something for everyone at very competitive prices even though our products are more expensive to build, Period.
Tekin Prez
Is this the tekin prez that was at the april fools in utah this year? This is brad church from colorado. I talked to you about introducing tekin to our club. We have a new club we are running on road in a parking lot. I would like to talk to you how do I get ahold of you. So we can see what TEKIN CAN DO FOR US!!!
bradchurch123 is offline
Old 05-04-2010, 09:50 PM
  #14391
Jim Campbell's e-mail: [email protected]
Phone: (208) 634-5559
Fax: (208) 634-5569
Or do a PM to Randy Pike for his take. He is on here a lot. Or look up Randy's e-mail address on the Tekin website.
Old 05-04-2010, 09:51 PM
  #14392
Geeze! I'm feeling like the Tekin secretary this evening...LOL
Old 05-04-2010, 11:52 PM
  #14393
Just had to chime in real quick and say i love my new rs 13.5
slackerman is offline
Old 05-05-2010, 12:02 AM
  #14394
kcunamay's Avatar
Trader Rating: 20 (100%+)
Originally Posted by Skiddins
As it appears to be a problem that only occurs with Spektrum receivers (only the micro 3500 version?) combined with the Tekin's, what does the Tekin do differently that might effect the receiver?
Would a brown out cause the ESC to go open throttle etc or only a shutdown?
Would a fault with the power cap casue any of the described issue's.
Skiddins
Happened to me today...while testing settings. Signal cut out, and came back after a few seconds.
After reading through this thread I replaced the digital servo with a 94358 and was able to drive around LONGER before it happened again. I replaced the CAP and NO MORE ISSUES on either servo. Cap didn't look blown, swollen or faulty. But upon replacing it, I had no more issues. Hope this cures your issues as well.
Equipment used:
Spektrum SR3001 pro RX/Module in an M11
Airtronics 94359 servo
Tekin RS, Redline 17.5
T.P 5200 50C/100C
T3
kcunamay is offline
Old 05-05-2010, 12:12 AM
  #14395
-WHEELMAN-'s Avatar
Trader Rating: 267 (98%+)
Finally got a hot wire to update my pro I'm running a B44 6.5 Redline on high bite track 120' straight 6900 sq.ft. Total.
Any sugestions for me with new firmware?
-WHEELMAN- is offline
Old 05-05-2010, 12:17 AM
  #14396
razzor's Avatar
the DSM issue is more in stock classes with the turbo software.
I would only get the problem out of teh hairpins or slowest corners where you slow down a lot and then get on the throttle hard.
Putting a cap on the esc made all the difference and no hassles since.
razzor is offline
Old 05-05-2010, 01:32 AM
  #14397
HarryLeach's Avatar
Equipment used:
T.P 5200 50C/100C
T3
EXCELLENT NEWS! Thanks for that, I have extra caps, so I'll swap mine out and see if it does the trick for me as well. Likewise, my cap doesn't look swollen, blown or bad, but it's gotta be something.
HarryLeach is offline
Old 05-05-2010, 05:07 AM
  #14398
20 SMOKE's Avatar
Trader Rating: 103 (100%+)
there is a tekin setup help in the offroad section krio is probable got the most help in offroad as i don't have any anymore,in dual mode timing advance 60-70 geared 19/84 everything else set to your liking,in sensored you have to be careful i would start with 30-40 timing boost end rpm 25k start 3k motor 0 delay 3 ramp 1 turbo low.gearing 14-15 fdr,go slow with sensored mode cause it is fast
20 SMOKE is offline
Old 05-05-2010, 05:56 AM
  #14399
Skiddins's Avatar
Equipment used:
T.P 5200 50C/100C
T3
OK, I'll try another cap then.
Anyone know the exact tech specs of the supplied item ( I can't find Tekins one in the UK at the moment) or recommend a decent alternative?
Skiddins is offline
Old 05-05-2010, 05:58 AM
  #14400
pakk's Avatar
Trader Rating: 80 (100%+)
16V 330uF
pakk is offline
