Tekin RS ESC sensored
I run on a very large outdoor track in NZ in a 13.5 class (big as in guys gear down as low as 4.0 in 13.5!).
I'm geared at 4.6 which is great for the infeld on our track.
Motor timing =
Boost = 45
Start RPM = approx 5000
End RPM = approx 18,000
Turbo = max
Turbo ramp = 2
Delay = 0.8
After a 5 minute run on a hot day i'm temping around 70 deg C, and the car pulls hard all day long.
I could gear-up, but I have plenty of in-field punch which I like. Racers are won and lost in the corners
Motor timing =
Boost = 45
Turbo = max
Turbo ramp = 2
Delay = 0.8
I wouldn't mind giving the redline tekin a try. It should pair up very well with the tekin RS/Pro.
Randy,
Got a question to ask.
Would it be ok if i use the Version 203 on a 5.5T or 4.5T Motor?
What Set-up might be possible???
Has anyone done that here?
I have used 203 in my b44 with a 6.5. You can definitely use boost to help get a cooler running motor, but it doesn't have the same linear feel as static timing. Feel was more important at the local indoor track and heat wasn't an issue so I stuck with v200. If you're looking to try it: Settings of 0 to 5 on the motor, 10-15 boost, and start/end of 5k/30k bring a new meaning to overpowered.
gearing..
ok..here goes,,,i have the rs with the redline 17.5...the track is 70x35 and technical...i seem to have not as much punch i would like off the corners...the car hesitates a bit then goes...here is my set up..
rpm end...18xxx
rpm start...3xxx
timing...50
boost...10
delay... .3
ramp 3
motor timing...24(max)
geared at a 6.9..(108, 31)
what do i have wrong...i have speed on straigt but not enough punch in the infield....
rpm end...18xxx
rpm start...3xxx
timing...50
boost...10
delay... .3
ramp 3
rpm end...18xxx
rpm start...3xxx
timing...50
boost...10
delay... .3
ramp 3
rpm end...18xxx
rpm start...3xxx
timing...50
boost...10
delay... .3
ramp 3
and lower your end rpm to around 15,000 and as low as 12,500
rpm end...18xxx
rpm start...3xxx
timing...50
boost...10
delay... .3
ramp 3
rpm end...18xxx
rpm start...3xxx
timing...50
boost...10
delay... .3
ramp 3
edit.i was typing krio and losi beat me to it
However, tekin advice to use dual-mode for mod motors. I think this will keep the esc cooler. So if you have 5.5 or 4.5 motors, its better to use dual-mode and play with gearing and the time advance setting.
Thanks for the info guys,
Will give it a try and maybe try some set-up.
If it's a advange over the Occa-wind motors will update.
Track here is quite mid-size with medium traction.
Running TC.
Running TC.
OK trying to further get my head around this speedy and how it works. I am running zero timing on the can with a duo 2 17.5. Anything else and it just gets hot and fades at the end of the run. I was playing with start and end rpm and found a really nice range to suit the track(2800ish-10k FDR 8.44). Started playing with the boost and turbo(40-15) but im not sure how this all ties in with the ramp, delay and throttle profile. Also whats the advantage of running lower boost and higher turbo vs higher boost and less turbo? Just starting to get my head around this speedy and im a bit stumped. Also the wildly varying FDR people are running is amazing. Any thoughts would be apprecaited. Cheers Benzaah
I'm in the camp of "gear it first, add timing to tune" rather than "time it to the limits" though...
