Tekin RS ESC sensored
#1291
hey guys i have a problem some where! and i really need help i have a 17.5 system from tekin and im running a finnal drive of 3.8, first off when i had a stock motor on the same track i ran 6.6? i have the timing on the can at 12 and in the esc its at 100 what am i doing wrong?
Thanks Jason
Thanks Jason
#1293
First "problem" is that the motor timing is ony at 12 degrees. Turn that all the way up.
What esc are you using?
Gearing will be different brushed vs. brushless everytime.
Joe: What motor are you using? Have you verified your sensors via the RS led tree? Cogging on a 13.5 generally leads to a bad sensor harness(you chaged it) and or bad sensor.
#1294
i have a tekin RS Pro that im using and i have it set at 95% timing. and what would be a good point to go to on motor timing?
#1295
A 17.5 motor likes almost all of the timing you can give it. So start out in sensored only mode, maximum motor timing on the motor. Gear accordingly.
Most of the team guys run 100 on the timing bar just in case of a sensor harnes failure during a run. If it were to come unplugged we are one of the only esc's that continues to drive the motor.
#1297
as long as the motor has adjustable timing YES
#1298
Then I tried the Duo 13.5 with Dual mode and cogged badly. I will try it out tonight and let you know what the result is.
#1300
I was trying the Duo 13.5 and I tried 2 different sensor wires and it made no different. I actually reloaded the profile last night and set it to senor only and hopfully it fixed my problem. I ran the car last week with the Redline 13.5with sensor only mode without any cogging.
#1301
roll out
Hi guys, what roll out would be best for a 12th scale on a track that has about low 8 second lap times, some guys have tried around 80mmpr but i felt to sluggish in the infield with that, I have the tekin 17.5 and rs speedo and the motor timing will be at 30 along with the speedo just in case. Is there a roll out that the tekin motor will realy perform well at? also what kind of temp is ideal for max power?
#1303
1/12th scale roll out and settings
After various communications and help from Randy my Tekin RS now rocks.
Motor Nosram 10.5 bl roll out 57 mm timing cranked as high as possible.
Drag brake 50
brake 60
neutral 0
throttle 3
timing 90
sensored yes
Car was fast and smooth and duration not a problem.Large track 14/15 sec laps 8 min racing.
Drag brake 50
brake 60
neutral 0
throttle 3
timing 90
sensored yes
#1304
For the low 8's track start at 70mm or 2.75"
For the track with high 9's I ran a 3.07" or 77.3mm rollout.
If you have the hotwire give these settings a try.
Sensored only
Timing at 90
Timing on the motor turned all the way up.
Throttle profile 4 or 5 depending on you driving style.
The set the brake strength and drag brake to your liking.
later
Dayton
#1305
I thought if you had "sensored only" the timing on the ESC didn't matter. I've heard some say, the only reason you would want to put the timing on the esc at 100..was incase the sensor plug came undone. Is that not the case?
