Tekin RS ESC sensored >
Old 03-04-2010, 08:31 PM
  #12946
theisgroup's Avatar
Originally Posted by TeamTekin
We are pretty close on our track. Double everything for 2s setups in TC. We see 6k to 8k in the corners and 30k on the straight with a moderate setup..
We can gear down and let the motor spool to 40k on the straight but it gets slower well before that. We can add gear until we only reach 25k on the straight and it gets slower. The magic is in between depending on the track.
Tekin Prez
that is good to know. I always thought I was leave something on the track with not being able to get close to the max no load rpm. i just figure there is a lot more time in the turns then on the straight so i figure I did not need to be the fastest down the straight.
theisgroup is offline
Old 03-04-2010, 09:33 PM
  #12947
Trader Rating: 12 (100%+)
Originally Posted by mikky32
What motor do you have and how many turns?
And 1 or 2 cell lipo?
Why BL-DL and not BL-FW?
May you use it in the races?
Set your Turbo on 0 and higher your Boost. st it to 45 to start with and find a good infield speed.
You can raise it as the motor stays cool.
As you than come top speed to short you can ad some motor timing.
But for a good setup give some more information about the motor.
Hi,
RS Pro + 17.5 Duo 2 in 2S LiPo WGT CRC GenX 10 (as previous post title say :-) )
BL-DL is for practice.
Thank you.
audriusv is offline
Old 03-04-2010, 10:11 PM
  #12948
Trader Rating: 16 (100%+)
Jim (and Yang),
How about an All Tekin Test Weekend? Or, a seminar for devotees. I'm willing to travel for that.
Just a thought...
Bill
Still Bill is offline
Old 03-05-2010, 01:57 AM
  #12949
Originally Posted by audriusv
Hi,
Thank you.
Ok didn't read the title sorry.
Than you have a very low Boost for a 17,5T.
This can cause that you don't really feel the Turbo.
Set you Boost to 50
You get more top speed and you don't need the Turbo.
As you still have not enough top speed, than ad some motor timing.
You can always ad some Turbo. This will give you extra top speed.
The more Boost you set the more you feel the Turbo.
mikky32 is offline
Old 03-05-2010, 02:21 AM
  #12950
Set you Boost to 50
Thank you Mikky32. It is just that my previous configuration was with SP V3 17.5 motor and that system was a little bit quicker, cooler and felt better than I have now with Duo 2. Ok. I will check what you have suggested and will try to find setup which works with Duo 2... Last (but not nice) option is to change motor...
audriusv is offline
Old 03-05-2010, 02:26 AM
  #12951
The DUO 2 is a fast motor.
For more speed as the Boost alone is not enough, try some motor timing.
Watch the motor temp.
mikky32 is offline
Old 03-05-2010, 02:35 AM
  #12952
2wdrive's Avatar
Hi,
Thank you.
i drove wgt with 2s lipo and 13.5t duo 2 on a small indoor track with 20-30 meter straight and had the following setups:
Boost 50
end rpm 9000
start rpm ~1500-1600
no turbo
rollout ~ 33mm
dragbrake 0
nw 12
bs 100 (turned to 40 on the radio)
other one i used last time was:
boost 54
end rpm 10.500
start rpm ~1700 or something
rollout ~33mm
dragbrake 0
nw 12
great speed out of corners and motor temp was only 45-50 degrees C after 7 minute race.
The first setup had a motor temp of 35-40 after 10 minutes but had more acceleration except on just over half of the straight it topped off. The second had a little more top end it seems. No motor fading whatsoever. Had standard motor timing.
For a 17.5t you should get a slight higher rollout then 33mm. Just look at the speed and motortemp and gear accordingly.
2wdrive is offline
Old 03-05-2010, 03:09 AM
  #12953
Ok. Thank you. Will try that setup.
audriusv is offline
Old 03-05-2010, 03:39 AM
  #12954
tc3team's Avatar
The motor rpms are rarely 4k or lower unless you make a mistake and literally stop. The motor is really not below 6k to 10k depending on the track. WIth the rpm at 6k or less the boost is always on and the benefits of adding it as the motor rpms increase are not there.
Our default rpms are stupid The high rpm value needs to be 8k to 12k at least to be really getting any sliding action on the boost. Even 8k may barely reduce the boost timing at all even at the slowest part of the corner.
Tekin prez
Thank you for the insight, it gives me a much better idea now of how the boost works
I will try using a value of 6000 start rpm and see if it suits a small track...
tc3team is offline
Old 03-05-2010, 05:29 AM
  #12955
avs
avs's Avatar
Originally Posted by theisgroup
i have only run 2 layouts with the same motors. since I have a novak sentry, i have no reason to try different motors at different tracks or layouts. i have a duo 1 17.5 from eXpress Motorsports. this motor was purchase before vegas 2009. i would call our track a big track. my low rpm was around 1900 and the high was 11,800 on the back straight and 8836 in the infield. this is with a 91mm roll out and a 40mm rear tire. the track is about 100x40 and we run about 3/4 of an oval for the back straight.
to give you an idea. without turbo or timing, my baseline was a low of 2968 and a high of 12,875 on the back straight and on the infield 8,042
I am not sure how much value these numbers are because imho tekin setups now need to take into account too many variable to make a setup work everywhere. I can tell you that this setup really is setup for our track the day I ran it. this was after 3 round of looking at sentry data and adjusting start rpm, end rpm, turbo delay and gear ratio. this setup was basically optimized as much as I could for the track. I was able to put a full lap on my best times. I rarely find any change that I can do that with.
Tekin Prez
guys, this kind of info needs to be sticky'ed or something
avs is offline
Old 03-05-2010, 06:35 AM
  #12956
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
for that one setting in hotwire that deals with concave throttle profile or whatever its called, what is a value to use to give it a linear feel? I see it goes from 1 to CST, but not sure what that means in relation to the setting. Does going higher mean more curve? Lower more linear? etc.
Also heard you guys are working on a more simple interface that isn't as busy as the current one and hopefully with bigger font, any timeframe on this?
Cain is offline
Old 03-05-2010, 06:57 AM
  #12957
pakk's Avatar
Trader Rating: 80 (100%+)
linear is 3.
pakk is offline
Old 03-05-2010, 07:06 AM
  #12958
Tech Legend
Cain's Avatar
So what does going higher than 3 mean, and what does going lower than 3 mean? Also, what does CST mean?
Cain is offline
Old 03-05-2010, 07:09 AM
  #12959
Higher is till 5.
It gets more aggressive.
The CST is custom settings but they are not there so on this moment 5 is the max.
1 the mildest reaction.
mikky32 is offline
Old 03-05-2010, 07:33 AM
  #12960
M-Technic's Avatar
Trader Rating: 15 (100%+)
With what turn motor?
I find this hard to believe simply from the fact that during my testing, I noticed a significant delay in the boost coming in when I switched from a 2,500 RPM start to a 4,000 RPM start. This tells me I am going below 4,000 RPM on some of our corners.
Our track is by no means small, even in our 180 hairpins you can carry some speed because it's a large outdoor asphalt track.
M-Technic is offline
