Tekin RS ESC sensored >
Old 02-23-2010, 08:47 PM
  #12586
Technique550's Avatar
Default ok
Originally Posted by wingracer
You should run 203 unless your track demands some other version. If that is the case, run what they tell you to run.
they say no to 203 but dont specify what to run so im trying to figure out what version to run I guess I am using 200 now is that the previous to 203?
Technique550 is offline
Old 02-23-2010, 09:00 PM
  #12587
wingracer's Avatar
Trader Rating: 24 (100%+)
yes, 200 is the next best option.
wingracer is offline
Old 02-24-2010, 12:08 AM
  #12588
Find a different track
chris_dono is offline
Old 02-24-2010, 02:59 AM
  #12589
hacker's Avatar
Trader Rating: 141 (100%+)
Default turbo values
with alot of recommendations by team tekin to not lower turbo less than 1.0 or whatever figure it is, the latest setups have turbos 0.5 or even down to 0.0
hacker is offline
Old 02-24-2010, 03:02 AM
  #12590
tc3team's Avatar
+1 if they can't even tell you what version of software you are allowed to use.... in effect that just says you can't race, which in todays age is just lame where some clubs are finding it difficult to keep racing alive or finding new blood...
(If they have though, then ignore my post).
tc3team is offline
Old 02-24-2010, 03:14 AM
  #12591
entitymugenmtx's Avatar
Trader Rating: 85 (100%+)
Hello who can help me? I have a 416we, and I just bought the tekin rs and I need a good start point with gearing.. The motor I'm running is a novak 13.5 ballistic with thunder power lipo 5200 50c lipo. My gear ratio is 2.055 and my spur is a 105
thanks David
entitymugenmtx is offline
Old 02-24-2010, 03:40 AM
  #12592
k_bojar's Avatar
Trader Rating: 30 (100%+)
thanks David
what type of track? open, flowing, tight
what surface? carpet, asphalt, etc
what kind of tires? rubber, foam
what version on your RS? v200, v203
I know Randy Pike posted a 'suggested' starting point for 13.5 TC a ton of pages back, you can do a search for his post
remember, there isn't going to be a 'perfect, outta-the-box' settings anyone can give - its all gonna be ballpark starting points
k_bojar is offline
Old 02-24-2010, 03:56 AM
  #12593
goBezerk's Avatar
Huge kudos to Tekin Being still fairly new to RC in general (approx 1 year) I've been slowly working my way through the various brand names of speedies and have to say that the Tekin RS has been an eye opener!
My 10.5t TC has been transformed from a moderately fast car to a guided missile, and the brakes are just awesome, so great that I had to raise my ride height to stop the front of the car digging into the asphalt As others have said, back your EPA off, I'm running around 50 percent!
If you're curious, setup is -
HB Cyclone on Asphalt, 45ish meter straight
SP V3 10.5t with minimal timing on the endbell
FDR around 7.04
Boost - Max
Start - 54**
End - 20000
Turbo - 16
Delay - 0.0
Ramp - 3.0
Comes off in the 60's and no complaints really. I found if you went too low in your gearing, say into the 8's, it got much hotter and actually lost infield punch.
Second RS on it's way to me to go into the RT5, yes it's that good
goBezerk is offline
Old 02-24-2010, 05:44 AM
  #12594
Skiddins's Avatar
Originally Posted by Pamork
Thanks i will try that out.
What timing did you have on the motor?
0, the default.
Skiddins is offline
Old 02-24-2010, 06:02 AM
  #12595
Originally Posted by Andy63
Hey!
I have looked into Tekin and wonder, wich Tekin is the best for 13,5 stock class and modified? I will run both and want the best out of it.
What i can read, do i need to have a computer to setup the ESC? if so, how?
Thanks! // www.andrefossto.wordpress.com
The RS Pro id the one you need.
mikky32 is offline
  #12596
theisgroup's Avatar
the suggestion is not run less then .2sec. 1.0sec is a long time. yes some of the setups are 0sec delay. remember those are suggestions and the setup you are seeing are "fully" optimized. remember these guys are racing at the top of the game. i am not sure that these setups would be an everyday club race setup.
theisgroup is offline
Old 02-24-2010, 06:12 AM
  #12597
The setups with 0 on the delay are risky and should be tested before you race with it.
I use it on an indoor track and I love the 0 turbo delay. The motor get's hotter bud the Acceleration is just impressive by full throttle. As you don't go on full throttle, you can drive easily true the infield. You can use the acceleration power when you need it.
As you use the 0 delay, use than also a higher start RPM.
This way you prevent of having to much timing at once to the motor.
mikky32 is offline
Old 02-24-2010, 06:18 AM
  #12598
avs
avs's Avatar
thanks David
hi David, assuming you are using a hotwire with the vegas203 firmware. if not, then go get a hotwire.
check out tekin's website for setups. Randy Pike's and Barry Baker's setup from the ko race is listed. thats a good starting point for an open track, try 7.5 fdr if the track is tighter to just get started.
you will want to fiddle with the start/end rpm with no turbo, then add turbo, its like a 2nd gear kicking in.
note the pro's tend to set the turbo delay to near zero, because they are using their trigger position to control when they get the turbo. for mere mortals and rabid racers (like me) a larger delay based on the track layout works better.
avs is offline
Old 02-24-2010, 08:11 AM
  #12599
hacker's Avatar
Default full motor timing
instead of the traditional setting of 0 motor timing and 50 timing boost, has anyone played around with max motor timing and minimal timing boost eg. 10-15?
can anyone see a downside to this setting?
sorry if it sounds like a stupid question,its currently 3 hours past my normal bedtime and brain doesnt function well looking for the extra few tenth's this time of hour haha
hacker is offline
Old 02-24-2010, 08:16 AM
  #12600
theisgroup's Avatar
imho with full motor timing, you loose all the torque that a brushless motor has. specifically the high wind spec have a lot of torque.
