Tekin RS ESC sensored >
Old 02-22-2010, 11:31 AM
  #12526
Would anyone have a fast setup for a lrp x12 running tekin rs v 203 for a small indoor track. 17.5 motor
HoboShop is offline
Old 02-22-2010, 02:53 PM
  #12527
tc3team's Avatar
Originally Posted by mikky32
You can buy 2 Tekin's for that price. That would be an expensive test.
Yes, maybe so. I have got to my place in racing now where I am happy with what I have in the car. It is my first and only brushless ESC that will see my car.
I like to have a very neutral view about equipment now. What wins somewhere may loose elsewhere. I don't spend money to make myself faster. I spend to look after my car and consumables, that's all, because that is all I need
I think it's good to see the bd will have future updates, to improve it just like the RS did - look at what has happened since v180!
I look at equipment now and think there is no "best" as this will depend on who is using it, but there is very good.
That said, I am still a TEKIN fan, always will be. I AM happy with the RS and the redline motor, for sure, 100%....
tc3team is offline
Old 02-22-2010, 03:07 PM
  #12528
here's what i'm using on a 10.5 (1S Lipo, so adjust rpm ranges especially for 2S)
-10 on motor
30 boost
10 turbo
delay: .4
ramp: 3
throttle profile: 4
start rpm: 1475
end rpm: 7000
chris_dono is offline
Old 02-22-2010, 03:12 PM
  #12529
-10 on motor
30 boost
10 turbo
delay: .4
ramp: 3
throttle profile: 4
start rpm: 1475
end rpm: 7000
I am sorry I should have added that I am using a 2c battery in a tamiya 416 we with thunderpower 5200 mah 50c tekin v 203
HoboShop is offline
Old 02-22-2010, 03:24 PM
  #12530
jammincrtjames's Avatar
Has anybody had their turbo not work?
jammincrtjames is offline
Old 02-22-2010, 03:28 PM
  #12531
Mine works from time to time, I will try to calibrate the ESC with throttle EPA set to 90 and then afterward setting it back to 100. It is weird, it comes and go.
Pyrosas is offline
Old 02-22-2010, 03:53 PM
  #12532
aside from the epa issue, are you running 0 boost by any chance ? It doesn't seem to work when on 0 boost (no turbo comes in)
Old 02-22-2010, 03:55 PM
  #12533
try the settings above but with a much higher rev range (3500 to 10000 for example)
sorry i can't be more help than that, i've not run it on 2S in a TC myself.
Old 02-22-2010, 04:29 PM
  #12534
Regional Moderator
Jon Carlson's Avatar
Trader Rating: 48 (100%+)
Maybe I'm misreading this but, you are saying when you have the Turbo Boost set to 0 it doesn't come in? That would be because at 0 you aren't telling it to add any timing. If you have your timing boost set that is where you are getting the advance.
Can you tell us your current settings so we can help you out?
Jon Carlson is offline
Old 02-22-2010, 04:41 PM
  #12535
clparsons123's Avatar
this happened to me this past weekend. i added travel to the throttle on the radio and it solved the problem
clparsons123 is offline
Old 02-22-2010, 04:50 PM
  #12536
Just picked up the RSpro and hotwire. I was told by a friend that it is not necessary to install the hotwire software that came with it. Is this true?
Obsidian is offline
Old 02-22-2010, 04:52 PM
  #12537
Interesting. I will try that. I think the radio needs to be re-calibrated. Makes sense.
Old 02-22-2010, 05:12 PM
  #12538
20 SMOKE's Avatar
Trader Rating: 103 (100%+)
JUST LEAVE THE CD IN THE CASE IT CAME IN AND GO TO TEKIN'S SITE AND GET 203,SORRY FOR THE CAPS
20 SMOKE is offline
Old 02-22-2010, 05:18 PM
  #12539
Will do. Thanx
Obsidian is offline
Old 02-22-2010, 06:11 PM
  #12540
here's what i'm using on a Novak 10.5 with 2S on a xray t2'008
45 boost
10 turbo
delay: .4
ramp: 2
throttle profile: 3
start rpm: 3,500ish
end rpm: 14,000
hardmankam is offline
