Tekin RS ESC sensored
Check if the esc wires are capable of delivering in excess of 6A to the radio so the servo is properly powered and assess if you should change them. I changed mine to a wire size equal to that of the servo I use (which is clearly heavier gauge than the little wires the Tekin comes with).
A powerful capacitor might just get you over the drain spikes but I don't regard it as a permanent solution if this is your problem.
hello, any settings suggestions for 17.5 redline BL, but i can only use the 200 software not the 203... im running in a class that doesnt allow the newer software.
10 motor 20 timing boost max turbo 4.5 5.0 fdr. since we can go more with timing on 203 if you need a little more add timing boost
So why no heat sink on this ESC? Is it just that insane that it doesn't need one?
Solder posts are the only heatsink needed - don't cut them down or insulate them (with heatshrink). It's not insane, it's just good design.
Today i joined the dark side
Try it by all means, but temp it after a minute or two. Personally I think it's too much timing.
thanks for the info
i didn't think the track change would be that big of a deal but befor the chang we had a sweeper going on the the stright and a sweeper exiting the stright now it's pretty much a 180 in and off the stright.
i'll try changing the rpm range and see what it does
No problem
Keep an eye on the motor temperature though, as that is always going to be your best indicator as to how hard the motor is working...
If you do need a pinion gear change, you might need 1 tooth lower to get more rip out the extra corner(s) put into place for the smaller straights, but it could give you more heat build up.
Also one last thing, i'm sure you are onto it already, but change the gearing OR the boost setting to help your progress, don't do them together...
I'd be careful running the X12 without changing the insert first. I span it up and it was overtimed with the 0 insert on 30 boost (40 on the motor by default apparently) so with the above setup, you've got 75 degrees at the top of the boost range, then another 10 at full throttle (85 in total)
