Tekin RS ESC sensored >
Old 02-09-2010, 08:48 AM
  #11941
Senna Racing's Avatar
Ha guys heading to Thailand next week
to race in the titc
We will be running hand out 11.5 speed
passion motors
Any ideas would be aprecated
here's a link
http://www.titc.in.th/
Senna Racing is offline
Old 02-09-2010, 08:53 AM
  #11942
niznai's Avatar
Originally Posted by Randy_Pike
Option 1 is your best bet. Option two would be too narrow of a timing curve and will not get you the torque down low where you want it. Their top speed would be similiar but the motor will run hotter in option 2.
You can take Option 1 and narrow it up a bit using a start rpm of around 2,000 and end rpm of say 7500 or so. This will be an "inbetween" the two.
Wouldn't introducing timing at low revs lose some of the torque? Sure the 2000 RPM low limit you suggest is not that low, but at 800 I would think option 1 is not ideal.
niznai is offline
Old 02-09-2010, 08:55 AM
  #11943
swimbikerun's Avatar
Trader Rating: 108 (99%+)
The RS is rated with a 5.5 in a 2wd application.
There are many factors involved in thermalling. Esc placement, air flow, setup, track size, driving style,etc.
In TC if you're going to run mod get the RS Pro.
Are people running the RS Pro or RS in 1/12 mod using a 3.5/4.5? The RS was rated at 5.5 with 2S. So with a 1s it should be able to handle a 3.5/4.5. I assume non of the Tekin guys can comment for warranty/liability reasons but anyone else?
swimbikerun is offline
Old 02-09-2010, 09:22 AM
  #11944
theisgroup's Avatar
if you are running those type of turn mods, I would get an rs pro
theisgroup is offline
Old 02-09-2010, 09:33 AM
  #11945
Team Tekin
Randy_Pike's Avatar
Actually less voltage means more current. The PRO will be needed for 1/12 mod racing with 3.5's etc. We've tested all the way down to a 2.5(yes it dumped , lol).
Donny Lia ran a 4.0T at Snowbirds, Mike Dumas ran a 3.5 at Vegas.
Randy_Pike is offline
Old 02-09-2010, 09:34 AM
  #11946
Team Tekin
Randy_Pike's Avatar
Yes and no. In theory this is correct more timing is less torque. I'm doing just that by telling him to raise his start rpm higher than 800. There is always motor timing involved so I'd like to see the car get rolling BEFORE the esc adds any timing.
Old 02-09-2010, 09:42 AM
  #11947
Tabushi's Avatar
Well guys, finally got my 2nd race with the Tekin RS PRO System on the 13.5 Brushless class.
First of all, thanks to all people here in the forum + Randy from Team Tekin for helping me out with ESC/Car setup for this track. Its very big straight for a 13.5 but at the end, all went great (198 feet straight).
Results (track people asked me to make this, organization people at the track got delayed and finally no podium picture was taken) :
And here is the video of last 8 minute round, wich gave me the victory :
+ YouTube Video
Hope you enjoy.
Under our racing regulations, race start doing "oval" or at least not entering into the layout until first lap ... crazy uh ? lol !!
Track "looks" dusty but its not, very good grip we dont know why after last maintenance, asphalt dont want to look "dark" even when washed and prepared, ended 2nd place on GT Class will try to post the video for you to enjoy lol !!
Made one big mistake by lap 3-4 but recovered ... looong back straight, lots of speed. Motor after 8 minutes racing ended on 147F.
cya and thanks again guys !!
Randy : Sorry for absence of Cap and Shirt man lol !!, as you know, i landed back into my country after a international job assignment just couple hours prior to the race, a friend picked up my stuff at my home and i went directly from the Airport to track ... lol !!!
Tabushi is offline
Old 02-09-2010, 09:50 AM
  #11948
JFuel11's Avatar
Trader Rating: 152 (100%+)
Randy,
Thanks for the reply. I will try the rpm range you have suggested. On a small track I was think that there might be a benefit to using the motors natural power band to get off the corner say from 1000 - 4000 rpms before you kick in the timing and then artificially boost the rpm range quickly once the motor is spinning from 4000 - 7500.
So the question is by ramping the Rpm from 2500 - 7500 more slowly will prevent the timing being added to quickly rather the other case where we add it all from 4000+ to 7000 where the motor is operating in an efficient range prior to the timing being added quickly, I could see where this in some cases would overload the motor with too much timing to quickly as well.
Let me know your extended thought and I will try the suggestion you have given as well this weekend.
JFuel11 is offline
Old 02-09-2010, 10:01 AM
  #11949
20 SMOKE's Avatar
Trader Rating: 103 (100%+)
congrats on the win tabushi,what are your settings and fdr.i will be going to kissimmee rc raceway for our state series race in a few months and it is a large track
20 SMOKE is offline
Old 02-09-2010, 10:04 AM
  #11950
theisgroup's Avatar
large is an understatement it is ginormous!!! lol
Old 02-09-2010, 10:29 AM
  #11951
20 SMOKE's Avatar
it is fun to drive on with nitro
20 SMOKE is offline
Old 02-09-2010, 10:38 AM
  #11952
Tabushi's Avatar
Thanks for your words man ... here we go :
ESC : Tekin RS PRO
Motor : Tekin Redline 13.5
Batteries : HEnergy 7.4v Lipo
Esc Programming :
Drage Brake : None
Brake Strengh : Full
Cut Off : Around 6.45
Timing Boost : 30
Turbo : 15
Turbo Delay : 0.8
Turbo Rampo : 2
Throttle : Min
Start RPM : +-2.900
End RPM : +- 13.000
Motor Timing : Stock (12 degrees)
FDR : 5.79
hope this help,
cya !!
Tabushi is offline
Old 02-09-2010, 11:22 AM
  #11953
Team Tekin
Randy_Pike's Avatar
Originally Posted by JFuel11
Randy,
That's exactly correct. Too much timing too soon will bog the motor down. We do want some timing though to allow the motor to make power and use the gearing we're stuck with for the rest of the track.etc.
You've got it though.
Old 02-09-2010, 11:24 AM
  #11954
Team Tekin
Randy_Pike's Avatar
Hey no worries! I'm glad we got you setup right with the little time you/we had. Next time shoot me the picture first and I'll have the guys photo shop it. We've got one of the best graphic guys in the business. Matter of fact send it to me anyhow, I need this info for our website! LOL
Old 02-09-2010, 11:27 AM
  #11955
Technique550's Avatar
Cool rs ?
newbie here just wanna ask if you know of a solid programming without using 2.03 software our track director is not allowing us to use the new sw for rcgt its a 17.5 0timing 6.2 fdr on a fairly large trak with good traction any help would be appreciated.
Technique550 is offline
