Tekin RS ESC sensored
Randy mod rubber 2nd place for Barry Baker.
Behind Jilles.
Behind Jilles.
Just double checked, 800x600 is the physical limitation for the screen, but i tried updating the driver for the tft screen to see if it make a differance and it allowed me to extend the desktop to 1024x768 (although looking through a smaller 800x600 window). When I did this, it allowed the advanced settings to expand. Thanks for the suggestion
I was called by some one that had the same problem but I didn't now that his screen was on 800 x 600.
after more than an our on the phone he told me.
than it was changing the resolution and it worked.
Randy when will the new update come for the pc?
Will it be with the profiles and can we save it to our pc?
What will be all for extra things on it?
Not really that amazing (info below cribbed from a post in the Snowbirds thread). Apparently, there are some complaints about the amount of traction available. In earlier rounds, 13.5s were only a tenth off mod times.
Fast Laptimes
17.5 Rubber = 11.8 - 11.9
13.5 Rubber = 11.4 - 11.5
Mod Rubber = 11.3 - 11.4
Fast Laptimes
17.5 Rubber Cuffs 11.7
13.5 Rubber Schreff 11.4
MOD Rubber Jilles 11.2
MOD Rubber Paul L 11.3
Hard to tell much of a difference between the classes now.
You've got to run the setup.exe file.
yeah i did that after it posted and i think it has worked , but my hotwire and car is still at the track so i cant chec it till tomorrow
looking forward to it now
Try start of 10,000, end of 27,000
Rollout is dependant on your track.
but below the track is a Landrover garage with a Ferrari 360 , an Aston Martin Vantage , Morgan Aero8 , and a Porsche 356 Speedster , and various 100,000 euro rangerovers in the showroom ,
but if you only want my Tekin , please do go see if it is still there
LOL it is at Tynaarlo
I don't care any more about your speedo.
OK I'm having problems with this new software, the issues is with me I don't really understand it. Heres my currant setup. This is in a 1/12th 17.5 car.
drag brake- off
brake strangth- 100
motor type- BL FW
lipo cutoff- off
push controll- 0
timing boost- max
turbo- off
start rpm- 875
end rpm- 8000
battery type- smc 4900 1s
rollout- 3.22
Track size- 36x60ft
straight lenght- 60ft
drag brake- off
brake strangth- 100
motor type- BL FW
lipo cutoff- off
push controll- 0
timing boost- max
turbo- off
start rpm- 875
end rpm- 8000
rollout- 3.22
Track size- 36x60ft
As the problem is with you, than your setup will be good. Maybe replace the driver
Get your start rpms away from 875. Try something more like 2,000.
