Tekin RS ESC sensored >
Old 01-07-2010, 05:49 PM
  #10246
Regional Moderator
CarbonJoe's Avatar
Originally Posted by LOW ET
i just made some adjustments according to your input and the motor is like a BEAST now
How can you tell? What kind of lap times are you running?
CarbonJoe is offline
Old 01-07-2010, 05:52 PM
  #10247
LOW ET's Avatar
Trader Rating: 109 (100%+)
lol, you didn't see it? man it must be fast
i just bench tested it and you can hear the difference in the motor.
LOW ET is offline
Old 01-07-2010, 06:08 PM
  #10248
tomdav's Avatar
Trader Rating: 44 (100%+)
Ok I have a question regarding turbo. I was bored today so I was messing with settings and bench running the car with zero boost and max turbo with .5 delay and 3 ramp. At full throttle it appeared that turbo did not kick in at all. I added about 20 boost and then tried again. This time at full throttle it sounded and looked like turbo kicked in. Why does nothing happen with max turbo and zero boost?
tomdav is offline
Old 01-07-2010, 06:13 PM
  #10249
Con
What is the diam of rubber tires??? 63mm?? I still run foam so I need to change the FDR in the settups to rollout
Con is offline
Old 01-07-2010, 06:16 PM
  #10250
LOW ET's Avatar
my sj-r's measure 64.5mm
LOW ET is offline
Old 01-07-2010, 07:51 PM
  #10251
Team Tekin
Tekin Prez's Avatar
It is there, it is just not as obvious at low timing. The difference in rpm from 0deg to 20 deg is not that big. The difference in rpm from 20deg to 40deg is huge and easy to hear. The difference between 40 and 50 is as big or even more. It is pretty exponential.
Tekin Prez is offline
Old 01-07-2010, 07:58 PM
  #10252
Regional Moderator
CarbonJoe's Avatar
With the flood of Android phones soon to come on the market (basically, Linux 2.6.29 kernel), it would really be neat to have a version of Hotwire for Android. Then your phone could be used at the track to update your RS, and no laptop needed! Motorola alone is supposed to come out with over 20 Android phones this year.
Old 01-07-2010, 08:09 PM
  #10253
tallyrc's Avatar
Trader Rating: 12 (100%+)
love mine, but you'd need a mini usb hotwire..
tallyrc is offline
Old 01-07-2010, 08:12 PM
  #10254
wingracer's Avatar
Trader Rating: 24 (100%+)
You can get adapters. I have a cable that came with 4 different plugs, including mini and micro usb.
wingracer is offline
Old 01-07-2010, 08:26 PM
  #10255
syndr0me's Avatar
Trader Rating: 32 (100%+)
Doesn't look like Android phones have USB host capabilities. I'm pretty sure the USB is just a bridge to talk to the RS via serial, so if Android can do serial you might have an avenue there. Does the RS use a PIC?
syndr0me is offline
Old 01-07-2010, 08:30 PM
  #10256
Regional Moderator
CarbonJoe's Avatar
Since Android is running Linux 2.6.29, I'm sure that it's only a matter of time before the open source community has a USB host driver.
Old 01-07-2010, 08:40 PM
  #10257
syndr0me's Avatar
It looks like there's been some efort in that direction already. It's not clear if all the phones have a chip that supports it, or if there's enough documentation available if they do.
Serial would be a simpler route. I've been meaning to sniff what's read/written to the RS to see how complicated it would be to reproduce via serial.
syndr0me is offline
Old 01-07-2010, 08:47 PM
  #10258
Regional Moderator
CarbonJoe's Avatar
Most of the phones are running a derivative of the Arm® Cortex™ A8 processor , or the Qualcomm Snapdragon (another ARM Cortex A8 core). The Motorola Android development suite is available for free from motorola.com.
Old 01-07-2010, 09:06 PM
  #10259
Doesn't the tether app work through USB? And it makes a serial connection through the USB to transfer files and sync...should be some way to make a droid based hotwire with that functionality.
InspGadgt is offline
Old 01-07-2010, 09:12 PM
  #10260
syndr0me's Avatar
It has no problem acting as a USB device, but hosting other USB devices is a different story.
Anyway, it's all beyond the scope of this thread. It seems like the hardware and OS are capable, but the support isn't enabled by default and may require lots of hacking, and then would be specific to certain phones. Once all that's sorted out, you can consider writing an app for it.
Or you can buy a netbook, they're cheaper.
syndr0me is offline
