Tekin RS ESC sensored >
Old 12-31-2009, 06:12 PM
  #9406
Originally Posted by 20 SMOKE
it sound stupid but you did uninstall the old first
yes and the hidden files. When you don't delete them you will keep seeing the same.
mikky32 is offline
Old 12-31-2009, 06:17 PM
  #9407
Default Any advantages?
I have a Tekin RS setting around and just wondering if I can gain any advantages using it to pull silver can in my M-chassis?
Please help!!
seasons29 is offline
Old 12-31-2009, 06:19 PM
  #9408
Trader Rating: 21 (100%+)
oh I didn't do the hidden files , I'll try again.
VA_Racer is offline
Old 12-31-2009, 06:23 PM
  #9409
vabroom's Avatar
Gee, leave this thread for a half hour and there's 5 more pages. Thanks Tekin for the early present.
vabroom is offline
Old 12-31-2009, 06:25 PM
  #9410
whynot's Avatar
Trader Rating: 18 (100%+)
do you have to delete thse files from teh computer or from the hotwire? It says current version 203 and under it is has previous versions 200,199,198 on the hotwire. are those supposed to be deleted. I notice it says the same in the pics that randy posted with the setups.
mike
whynot is offline
Old 12-31-2009, 06:28 PM
  #9411
tc3team's Avatar
cars are pulling 8k rpm now with the latest software- guys, that is more than a typical family sedan car rpm
I'm not saying use it to your advantage out there, all i'm saying is be careful out there in choosing your gearing and ESC settings.
if in any doubt in a 5 minute run, pull it in after 3 minutes and check your temperatures.
Brushless tech is far from cheap, i'm just saying "be safe and enjoy your racing!" that is all.
we have the latest hotwire software to make you fast, just be careful in how you get there, that is all I am saying.
We are much, much more advanced than we were in the v180 days!
have fun guys, safe racing... if in doubt, always temperature check mid run. better safe than sorry. i'd HATE to see anyone burn up.
that is all...
if i didnt have a family and 2 sons to consider, i would have re applied for sponsorship for 2010 but family has to come first!
tc3team is offline
Old 12-31-2009, 06:33 PM
  #9412
20 SMOKE's Avatar
Trader Rating: 103 (100%+)
mike
if you see 203 on versions that it
20 SMOKE is offline
Old 12-31-2009, 06:34 PM
  #9413
tc3team's Avatar
Please help!!
we have a lot of FETs to make the drive frequency as smooth as possible, all im saying is brushed motors work very differently from brushless motors.
you could do A LOT worse than strapping in a brushed motor to an rs speed control, as with any brushed motor, the key factor is gearing.
wheel the car consistantly enough and the ESC will serve you well...
tc3team is offline
Old 12-31-2009, 06:53 PM
  #9414
tc3team's Avatar
Please help!!
wheel the car consistantly enough and the ESC will serve you well... ive been with the team for 3.5 years, if the ESC was not advanced enough to be used as a brushed ESC we would not have done it.
Jim and the programming/R&D on this ESC is second to none. Forget about the G11 Pro or FX pro, we are in A main form with the RS/Pro with this ESC in brushed mode. just count the FETs to understand our build quality...
if you are really anal about laptimes, comparre your existing equipment VS an RS strapped in your car and make comparisons.
Hope that helps.
tc3team is offline
  #9415
well I've uninstalled it and searched the computer for anything with tekin or hotwire deleted it and reinstalled and still cant see 203
VA_Racer is offline
Old 12-31-2009, 07:01 PM
  #9416
20 SMOKE's Avatar
are you on 32,64
20 SMOKE is offline
Old 12-31-2009, 07:02 PM
  #9417
VA_Racer is offline
Old 12-31-2009, 07:03 PM
  #9418
John Tag's Avatar
Trader Rating: 42 (100%+)
Make sure your removing from add/remove main file area..Not just from desktop ect.
John Tag is offline
Old 12-31-2009, 07:04 PM
  #9419
Originally Posted by andrewdoherty
I'd love to hear how you determined that a 17.5 spools to 7k in .1 seconds.
On the bench I have 17.5 motors spooled out to ridicules RPM's, but on the track I find different values due to the load. Just for fun . . .
Lets say your 17.5 12th scale hits 24 mph at the end of your straight with a 3.35" rollout.
24MPH / 60 = .4 Miles Per Minute
.4 MPM x 5,280 = 2,112 Feet Per Minute
2,112 FPM X 12 = 25,344 inches per minute
25,344 IPM / 3.35 IPR = 7,565 RPM
For those mathletes who wanted, by knowing your speed at the fastest section of the track, you can work backwards to the end RPM to input.
Sorry guys guess I didn't go back far enough to see you were talking about a 1S 12th scale set up not a 2S touring car or off road set up. The RPM figures I quoted are for 2S and are taken from a Novak Sentry with RPM sensor connected to motor sensor cable. Buggy peaks out at 34.47mph with IPR of 1.88 giving max RPM of 19400. Of course in the air with no load it gets well into the 30k range.
7000 max RPM sounds quite reasonable for a 1S set up but would be way too low for 2S. Think we need to be sure to specify 1 or 2S clearly when giving set ups, will make sure I do in future
Marman is offline
  #9420
Super Moderator
J.Whiting's Avatar
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 63 (100%+)
Originally Posted by oeoeo327
Kenny Lambert's setup is probably pretty close,but plan to adjust the rollout a bit - see page 626 for the setups Randy has posted...
what was kenny's tire size?? so we can figure out roll out....
J.Whiting is offline
