Tekin RS ESC sensored
#7831
Randy you got mail.
I don't think that you can read the text but as I must translate it, it's not a problem. All of it is in Dutch, only that part is in English.
#7833
Okay guys, I need some help. I have the Novak Ballistic 13.5 in my 12r5 along with the RS. I have not touched the timing on the motor. I believe the instructions say that the motor comes set to 30* of timing from the factory. So here is my concern: what should I set the RS as far as timing, turbo, and throttle? This will be a starting point for me. I forgot to mention the motor I am running with the esc, Yang.
#7836
I don't remember having seen this question before but I hope someone has run across this because I'm stumped. Anyway in TC last night every run the turbo disappeared.... worked at the beginning of the qualifier/race and somewhere in the middle it went away. Any reason it would just stop working?
Motor DUO 17.5 - 0 deg
Turbo - Max
Boost - 19
FDR - 4.78 - 110 deg after race
Turbo - Max
Boost - 19
#7837
Turbo - Max
Boost - 19
Turbo - Max
Boost - 19
#7838
I am running a 13.5 redline with the RS in a TC4.
I am fairly new to onroad and noticed my temps
were at 160ish after a 6 min run. Is this too high?
I am used to running the Tekin in my B4 where temps
stay at 125 or so. Here is my current set-up:
The track is carpet and is shown here: www.outbackraceway.com
drag brake: off
brake: 60
neutral: 56
throttle: 3
push: off
timing: 23
turbo: 16
delay: 0.3
pinion: 26
spur: 72
FDR: 6.92
battery: SMC Lightning Volt 5200 24C
any suggestions on my heat or any other
part of my setup would be great
Also. I switch my RS between my TC4 and
my B4. I use velcro to hold it down, but in
the TC4 it does not stay fastened to the chasis
with the Velcro. Any tips?
Thanks.
drag brake: off
brake: 60
neutral: 56
throttle: 3
push: off
timing: 23
turbo: 16
delay: 0.3
pinion: 26
spur: 72
FDR: 6.92
Thanks.
#7839
Turbo - Max
Boost - 19
Turbo - Max
Boost - 19
Also, if you radio creeps it makes it go away. I get this at my track when a 4pk is in my heat. Set your throttle to like 90/95 and then sync it to the esc. Then turn it back up. Seems to work for me.
#7840
The EPA trick is THE cure. Its been on almost every page of this thread since the release of V200.
#7841
If your delay is set to low and you're not winding out before it hits it seems to go away/ not kick in properly.
If your delay is set to low (do you mean a low number i.e. 0.2?) then wouldn't the turbo kick in sooner and you should feel that sooner ?
Not winding out. Does that mean there is a length of time that has to pass (this would be the winding out portion, depending on gearing ?) before the delay time has to pass and THEN the turbo kicks in ?
If your off the throttle before any of these timed events happen, does that mean you won't feel the 'kick' ?
This is assuming that you don't have any throttle 'drift'.
Thanks.
#7842
think of the turbo as shifting into overdrive. If the car is not going fast enough when you shift it will just bog down. So if the delay is too short, the car will just go slower, not faster.
john
john
#7843
I just got my RS yesterday so it's all new to me. So I have some questions ........
Thanks.
Thanks.
Think of the turbo delay just like the gearing in a real car. If you shift too early the engine will bog down and not much will happen until the engine hit's it's powerband. Shift later when the revs are up and it will pull a lot harder in the next gear.
Running too much boost is just like skipping a gear and it will take some time to spool up and go.
It's all a balance and it's probably best to gear without turbo first and then tune in the turbo a little at a time to get tuned in. Full boost full turbo and minimum delay may not be the way to go.
#7844
Thanks for taking the time to answer. WOW ! here's the incredible thing .... I've raced with Fred B. for quite a few years but unfortunatley last year he dropped out (due to the poor enconomy I think) so I haven't been able to pick his brain.
#7845
Does anyone know if there is a version of Hotwire software that works with Vista 64bit yet? I found a post on the Tekin forums from march saying it should've been out soon after that and I still haven't seen anything.
Now with Windows 7 available, is Tekin planning on supporting that? Again in the 64 bit version?
