Tekin RS ESC sensored >
Old 09-10-2009, 07:37 AM
  #6931
TimNJ's Avatar
Trader Rating: 50 (100%+)
Originally Posted by mike ivy
Anyone have a 1/12th scale setup they can pm me? I need one for lipo 13.5 and nimh. Any help would be greatly appreciated.
I posted mine about 20 pages back, but have since made some tweaks to get it better. I dropped the boost by 5, cranked the turbo and lowered my rollout by about 5-6mm
Very small track with medium grip. I'm running a 12R5 with SMC 4900 40C lipo, Tekin RS/Redline 13.5, Novak Smart Boost.
Sensored Only
BL/FW
Motor Timing: 0
Boost: 25
Turbo: Full
Turbo Delay: .5
Drag Brake: 0
Brake: 100%
Throttle Profile: 5
Rollout: 81.3mm
TimNJ is offline
Old 09-10-2009, 04:00 PM
  #6932
mike ivy's Avatar
Trader Rating: 51 (100%+)
Hey TimNJ,
Thanks for the info very much appreciated
Sensored Only
BL/FW
Motor Timing: 0
Boost: 25
Turbo: Full
Turbo Delay: .5
Drag Brake: 0
Brake: 100%
Throttle Profile: 5
Rollout: 81.3mm
mike ivy is offline
Old 09-10-2009, 04:41 PM
  #6933
Skiddins's Avatar
Perhaps Randy can answer this question once and for all;
Does the reduction in voltage to a BL motor 1s instead of 2s for example, mean the BL motor is going to try and draw more current?
Or are they like the old brushed motors in that respect, i.e. when the voltage drops the current drops?
Skiddins
Skiddins is offline
Old 09-10-2009, 08:01 PM
  #6934
Originally Posted by Official
Hi,
Running on the same track too. But with top Photon, well started to have that problem initially but now think i got it settled.
Try adding the Roche power caps that BK has, I've geared mine to 6.99 FDR but i'm running on a 5T LRP X12. Using 2 fans blowing on the Post. and my set-up for mods motor is as below
motor Timing = 0
Timing boost = 15
Drag Brake = 0
Braking power = 80
Turbo boost = Max (bit Over kill)
RCRC is really a small track compare to the one they have, So set everything for the inner track, Keep the Turbo boost for the long straight(Don't think quite needed for mods) If you joining the This coming ECG Nationals Hey good luck bro. See you on track.
thanks!
Will try adding the power caps..
I am no good for races but just like this hobby very much.
Is turbo boost = timing boost? (Don see a selection for turbo boost..)
From the hot wire can only see selection for timing boost,
Guess will try a 6.5T for my next run and have a fan on the posts and of course gearing it light. 3.5T is a bit overkill i guess.
Cheers!
benokw is offline
Old 09-10-2009, 08:18 PM
  #6935
cyanyde's Avatar
Turbo only in V199/200 software in Sensored mode.
cyanyde is offline
Old 09-10-2009, 08:39 PM
  #6936
Another nooby qestion:
How to get the V200 software?
When I tried to update through hotwire, it says "no new software found for ESC"...
Cheers!
benokw is offline
Old 09-10-2009, 09:37 PM
  #6937
corallyman's Avatar
Trader Rating: 101 (100%+)
Cheers!
You need to ask for it from Randy Pike, the Tekin team manager. He is in Vegas at the moment though at the IIC race. He will send it to you through email, its not on the website as far as I know.
Steve
corallyman is offline
Old 09-10-2009, 11:12 PM
  #6938
Team Tekin
Randy_Pike's Avatar
So far here at the IIC on 1s we're seeing lower motor temps. However in general if you lower voltage you do increase current draw.
However setup will change with a 1s so it's not apples and apples ya know?
Typical 1s setups in 13.5 right now are 8 degrees on the motor, 22 on timing boost and full turbo with .3 delay(yes I can do this! LOL).
Temps are in the 120ish range.
WGT has a similiar setup as 1/12 with temps in the 140 range.
Randy_Pike is offline
Old 09-11-2009, 12:10 AM
  #6939
Trader Rating: 14 (100%+)
Is the "Smart Boost" a necessity when running 1S ?
Deznuts05 is offline
Old 09-11-2009, 04:00 AM
  #6940
tallyrc's Avatar
Trader Rating: 12 (100%+)
.3 delay? does this mean we will be able to do this?
tallyrc is offline
Old 09-11-2009, 06:32 AM
  #6941
jkirkwood's Avatar
What's the roll-out in 13.5/1s LIPO people are using there? I'd like to know how far I'm off or how close I am. I concur with the heat I haven't seen a properly geared 1/12th with LIPO get higher than 135 deg after a 8 min run.
jkirkwood is offline
Old 09-11-2009, 06:51 AM
  #6942
Can the V200 run also 0.3sec Turbo delay with 1s?
mikky32 is offline
Old 09-11-2009, 06:54 AM
  #6943
STLNLST's Avatar
Trader Rating: 32 (100%+)
Randy,
Don't forget to slap Art
STLNLST is offline
Old 09-11-2009, 07:40 AM
  #6944
Company Representative
ammdrew's Avatar
Trader Rating: 25 (100%+)
When can I , It would be very helpful..
ammdrew is offline
Old 09-11-2009, 08:22 AM
  #6945
liljohn1064's Avatar
Trader Rating: 17 (100%+)
NICE! A rollout as mentioned before would be great.
Thanks again for taking the time out of what must be an insane schedule this weekend.
liljohn1064 is offline
