Tekin RS ESC sensored
#6916
I think I found em now to get some free time to chat
#6917
#6918
I need more info to help out. I'm guessing that you're setup wrong and or geared wrong.
Most of our team doesn't run a 3.5 on asphalt. Most are running 4.5's and 5.5's on 2s lipo. Is this 5 cell?
A second cap will help along with a fan blowing on the solder posts as suggested. Can you also post a pic of your cars layout?
Hers's a pix of my setup...
Unable to paste a link of a video of the track.. But do search for "Track at bottle tree park" at youtube for a clip of the track..
Perhaps the motor is not suitable..
Had just put a fan on the solder post, but not tried to run yet..
Due to the light lipo (project 2s) had to add some weight on the right to cure the tweak..
My setup:
84T spur / 17T pinon - FDR 8.4
Drag brake 30
Profile linear
Timing 0
Current limiter off
Mode sensored
Tires 36R/ Medium inserts
Thanks guys!
#6919
Hi,
My setup:
Drag brake 30
Profile linear
Timing 0
Current limiter off
Mode sensored
Thanks guys!
My setup:
Drag brake 30
Profile linear
Timing 0
Current limiter off
Mode sensored
Thanks guys!
#6921
Tekin RS + Novak Ballistic 21.5
Anyone have any setup sheets for an RS combined with a Novak 21.5 Ballistic or SS? Looking to set up for indoor carpet if anyone can help me out.
#6922
CLunker I will look I may have one or two set ups. I just wanted to tell tekin i purchased the rs after the review on rctvlive. I was a bit nervous about having to toy around with perimeters on a computer. I can not see doing it any other way. it is a great esc. you guys rock, good luck in las vegas.
#6923
#6924
#6925
Hi,
My setup:
Drag brake 30
Profile linear
Timing 0
Current limiter off
Mode sensored
Thanks guys!
My setup:
Drag brake 30
Profile linear
Timing 0
Current limiter off
Mode sensored
Thanks guys!
Running on the same track too. But with top Photon, well started to have that problem initially but now think i got it settled.
Try adding the Roche power caps that BK has, I've geared mine to 6.99 FDR but i'm running on a 5T LRP X12. Using 2 fans blowing on the Post. and my set-up for mods motor is as below
motor Timing = 0
Timing boost = 15
Drag Brake = 0
Braking power = 80
Turbo boost = Max (bit Over kill)
RCRC is really a small track compare to the one they have, So set everything for the inner track, Keep the Turbo boost for the long straight(Don't think quite needed for mods) If you joining the This coming ECG Nationals Hey good luck bro. See you on track.
#6926
#6927
Trader Rating: 51 (100%+)
Anyone have a 1/12th scale setup they can pm me? I need one for lipo 13.5 and nimh. Any help would be greatly appreciated.
#6929
Can somebody send me the hotwire with 200 firmware for RS, PM me!
#6930
