Tekin RS ESC sensored
#4786
At the moment I've tried a Novak and a Roche Prince (rebadged SP).
What's quite clear so far is if I gear appropriatly then adding boost gives the same top speed and less punch on my little indoor track. Is that supposed to be the way it is or have I got something wrong?
#4787
#4788
There is also a video that enplanes how to install it and how to remove the older version.
Than you will have the boost as you check the sensord.
The Turbo will come soon.
#4789
Give it full boost, zero or very little motor timing then the rest is up to you really. I turn reverse off and have full brakes, no drag brake and as I use LIPO, set a 6.5 V cutoff. Profile is a personal thing and run sensored only. I found quite a bit of extra pace by adding a little motor timing as well as boost but that heats motor up a lot more than boost, and was very limited before pace fell off again with too much timing.
#4790
#4792
Hi guys.
This turbo feature looks hot.... I know these things take time and that, but there is a big UK National here next weekend... I was wondering if we are likely to see anything by then?
If not.... Do you need anymore beta testers
Keep up the good work...
#4793
back off you
#4794
everyone needs to stop whining and crying unfair about 199. just relax 200 will be out soon enough and all will b good. crying unfair is not going to make it come out any faster. and besides why would you want to get a version that has known bugs??? some people just make no sense. or have none
#4795
Fair enough question in my opinion!
#4797
#4798
Guys I'm having a hesitation problem w/ my RS pro... I can slam the throttle and its a good second to 2 seconds before the car takes off.... the speed control sees me slam the throttle and sees it all the lights light up... the motor is a novak 21.5 running sensored only mode and i confirmed the sensor wire is plugged in correctly.... I rebinded my spektrum, re programed the speed control back to defualt settings and its still there and re-did the full throttle neutral and full brake settings as well.......
I have version 199 software...
Alex
Alex
#4800
What about using 198? Perhaps you are experiencing the bug they are talking about with the unreleased 199 version?
Maybe try a different sensor cable?
Could also happen if you have some debris in your motor. When was the last time you cracked it open and cleaned it out?
