Tekin RS ESC sensored
#4231
The Novak motors ballistic series is 20 degrees of timing the factory!!! (3.5T)
#4232
Would I be right in saying that by marking the centre of the total movement clockwise and anti clockwise on a Novak would give the point of 0 degrees timing? In other words, can the Novaks be retarded as much as advanced?
#4233
The velociti novak motors do not come at 0 timing! This has been the cause of many overheated motors where people assume that no timing marks/non-adjustable means 0 and then boost the heck out of them. The motors come with approximately 15 degrees, but I have been told anywhere from 12 to 20. Give novak a call to find out what your motor is most likely at. When I was still running novak motors with my RSpro I would use 15 boost on small/med tracks and 20 on very large tracks.
#4234
For 17.5 try starting out with full boost on the speedo and minimum timing on the motor. From there you can add motor timing a little at a time if you need more speed on the straight.
When you add motor timing the gearing will get more sensative. Be careful and it will take a lot less gear if you add much timing to the motor. Remember to gear for laptimes not motor temperature. Only check the motor temp to see that the motor is not overheating (170 deg F is about as high as you want to go with the Novaks).
#4235
If the Novak is truly at 25 deg., play it safe and add 5 boost. Gear to about 4.0 FDR and watch temps.
For reference, my 17.5 FDR is about 4.2 with about 5 deg. on the motor and 25 deg. boost.
#4236
NO! Do not run full boost in the speedo if your Novak motor is fixed at 25 deg.!
Simply turn the motor timing down to minimum. It's not that hard. The Novaks seem to run better with high boost timing and low motor timing.
Your results may vary but I've run plenty with the 17.5 Novak motors with the set-up I described. Just watch for heat like I said.
#4237
Thanks for all the input, guys. I'm gonna run this setup in TCS which doesn't allow you to change the timing on the motor (?). I'm gonna play it safe and add 5 degrees on the ESC and see what happens. I'll also go conservative on the gearing, start at 4.5 and go from there.
#4238
Judging by how the sensors line up no. Minimum timing on the motor probably has some advanced timing. Most motors have some timing advance built in at minimum timing.
I would not start with any timing added to the motor. You can add some motor timing a little at a time as long as you gear accordingly and watch the temps.
Go too far with the timing and you'll just get a hot motor (regardless of gear) and if you go to the extreme, it will start to cog and run funny.
#4239
Hi
I am a new GM120 user, so cand you answer me a couple of questions please
I normally run a GM 13.5 motor with a Nosram SPEC esc in mode 8, and am geared at 5.7, what will my gearing by now in mode 8 on the GM120
Also when im outside on tarmac, I am geared at 4.5 with the Nosram with a GM 13.5 motor, what will be the gearing now please.
Also I don't understand what you mean by mode 8 copied onto mode 3, please explain
Cheers Malc TCCFM
Cheers Malc TCCFM
#4240
Hi
Cheers Malc TCCFM
Cheers Malc TCCFM
#4242
Too bad this has gotten so complicated. We need to verify, but my guess is the motors are set around 10deg physical timing like they have always been. That means the real timing is about 25deg or more because of the 15deg 'early read' of the sensors seeing the magnet coming. That is what we should have been talking about all along is the real timing, but not all motors have the same offset so the physical position of the sensors is what we talk typically talk about to be consistent. People can see it and understand it.
IE if you set the Tekin motor at 10deg on the endbell you really have at least 25deg of real timing. Unless I am wrong the setups should not change much with the new Orange motors. You should still figure they are set at about 10deg to get your 30total between motor timing and boost timing.
To be sure we should ask Scuba Steve if that 25deg is physical position of the sensors or real timing.
Tekin Prez
Tekin Prez
#4243
#4244
Tekin Prez
Tekin Prez
From what you said above, should we still consider this as 10* and set ESC timing at 20*? Sorry if that's a dumb question, as this stuff is confusing!
#4245
now im really confused.
So, with the old software, 30 max boost was really 45 total timing including tekins inbuilt 15 timing sensored mode, IF motor timing was set to 0, which in most cases is set at 10.
So if I set my 30max boost, then the total timing I have been using is 30+15+10=
55 total timing?
55 total timing?
