Tekin RS ESC sensored
#3946
2 - I think the new "scale" is to reflect the actual timing rather than just the timing added by the boost. As has been said numerous times, in sensored mode even if you set the timing on the motor's endbell to 0 degrees you'll actually have 15 degrees because of the way it works. So 30 degrees of boost and 0 motor timing is in fact 45 degrees of timing which is what is shown by the new hotwire.
#3948
Thats the only gripe i have with Tekin at the moment.
"2 - I think the new "scale" is to reflect the actual timing rather than just the timing added by the boost. As has been said numerous times, in sensored mode even if you set the timing on the motor's endbell to 0 degrees you'll actually have 15 degrees because of the way it works. So 30 degrees of boost and 0 motor timing is in fact 45 degrees of timing which is what is shown by the new hotwire."
to clarify if i was using a SP motor which has 12 deg timing i would add 15 deg and if using 20 degrees boost would effectively be running 47degrees timing ? is that correct ???
Think that would be pushing it.
#3950
I drive with the speedpassion with boost on 23.
THis because we have a longer straight.
I have a total timing of 50.
On smaller tracks i drive 40 tot 45 total timing.
#3951
So,
I'm just curious, but is it better to runner a smaller pinion and increase timing or leave timing the same and adjust your gear?
Or are you using timing to adjust the car when you get the Final ratio you want?
Josh
Josh
#3952
#3953
just a question on the push control. Does it help a brushless motor to "coast as well or is it purely for brushed motors? or is it with push control and brushless motors that the motor is still running a little when i go from full throttle to no throttle if i put push control on?
If so how would that work with drag brakes then? Is it then that when i leave the throttle from full throttle to no throttle that first the drag brakes are applied and then after a while i get the coasting effect? That would be interesting to use.
edit:
Ok i tried it just now cause i was curious. Put coasting on 40 and hold my car up in the air and the effect is just the opposite then what i thought! After i leave throttle then first coasting is applied and then after that draggbrakes are applied. Hmmm maybe i can use that as well lol but would have preferred the other way around more.
Maybe an idea to put an extra function in hotwire to sellect wich effect you want? First dragbrake and then coasting or first coasting and then dragbrakes.
edit:
#3954
edit:
edit:
#3955
well the reason i want both is this:
1. I want to have drag brakes as it is something wich is a constant factor and my brake finger is not :-). I can slow down later for a turn because the brake is automatic. Only have to leave the finger of the throttle.
2. The downside is when i don't want to brake but only coast through a u turn for instance then i can't do that cause of the dragbrake. I then give a little gas but it happens that throttle is first on neutral ( it will brake instantly then) and then coast through the u turn with just a little throttle. It is not a fluent movement and it slows the car down.
3. when combined i can coast better through turns ( just have to find the sweet spot of the amount of push that is nescesary for my track, should not be much but just enough for when i leave throttle that dragbrake are not imediatly applied) but i still have dragbrakes when i have to brake after the long straight.
I gues the speed controller will get a little more heated cause it needs to do more work but i have a fan installed so no problems.
These are just my ideas of how i can use this feature. It could be that it drives horrible in reality and after one round i just put it back the way it was lol
#3956
I drive on a track that is bigger than a indoor track and to compensate the top speed i use 50 timing instead of 40 to 45 timing.
What track do you drive? how big is it?
Normally 45 is the best on most tracks.
If you come top speed to short you can ad some more boost but keep it than around the 50 timing.
On smaller tracks like indoor tracks keep the max on 45.
0 on the motor and boost on 30. that is a good setup.
tried it here and the acceleration was great.
Because of the long straight i hath to go to 50 timing.
lost a bit of acceleration and got some more top speed.
I don't have a SP GT esc.
Don't now how it works.
I have a Speedpassion 10.5T motor, LRP X11 10,5T, Tekin Redline 10,5T and some mod motors and a 9,5T Speedpassion motor.
And most important, a Tekin RS Pro esc.
That makes the motors go fast.
#3957
It defiantly sounds like you’re driving style require drag brake, keep the PC turned off, the only thing you can work on is to try and improve your braking skills to allow you to use a lower value of DB, making it easier in those “U turn” situations. Also keep it present in your mind that the DB is only ever active when the ESC see’s neutral, as long as you provide a tiny bit of throttle you’ll be free from the braking effects.
If you find your braking to be to inconsistent, it is helpful to turn down the brake strength for smoother braking.
#3958
#3960
If you strictly use drag brakes to brake I assume you have a flowing driving style and even if you had brakes you wouldn't use them much anyways. I would suggest setting up push to your liking and then lowering the brake strength so you can grab full brake on your radio and it will apply the same amount of brakes as your previous drag brake setting.
