Tekin RS ESC sensored
As I'm running 17.5 Blinky, I can not mess with the Throttle profile (yes I should have said that... Sorry). It is a clear delay in the response time, not slower start then others response.... I pull the trigger and I can see delay... I will try these 2 and see if that helps... Thanks...
Sure you can. Throttle profile controls how aggressive the throttle is vs. amount the trigger is pulled.
Timing profile is how much timing boost is used. For blinky, you have to use timing profile 1, but throttle profile can be changed. Think of throttle profile as throttle expo or throttle curve. It doesn't affect motor timing at all.
Will changing my minimum throttle setting change how smooth my kit is off the line? I think if I lower it, it will give me a couple extra steps of low throttle? Right now I have it at the default 3. Anyone running it lower then that? Looking to lighten the pop you get when you first touch the trigger on a 2wd buggy.
I'm also using concave throttle curve as well.
Having a problem with my rs, i have tried 2 different motors and getting the same concern. At full throttle( all lights on n blinking) i get full boost and turbo and the my motor starts to lose power or will hiccup and lose power to a point that it feels like its in blinky mode. I have tried 2 motors17.5's , different sensor cable, rebinded remote, turned down all my settings to a lower boost n turbo.......
And tried different batteries
Esc?
Any ideas yall?
Esc?
Any ideas yall?
This can be a few things. What motor is it? Are you testing this in the air?
1st motor is tekin 17.5 sensored, second one is older novak 17.5 sensored
noticed this first on the ground but when you pick up in the air it will also do it. Full power the car will slowly die/slow down. i have changed timing to next to nothing and still does it.... i have no idea!
This may have been discussed already but I would like to use your advise.
I currently set my RS TP = 3 then adjust throttle curve by M11x's exp and arc.
Do you guys adjust TP by RS or your radio? or may be both?
Case1: RS TP = 3, Radio Exp and Arc adjusted to advance.
Case2: RS TP = 5, Radio exp and other throttle adjust meant flat.
Case3: Both of above.
Thank you for your sharing.
Takeshi
Takeshi
Takeshi
Takeshi
My RS Pro was working fine with 212 installed. I updated to 223 and now it just shows leds 1,2 6 and 7 like the wrong motor type is selected. I tried different motors and sensor wires even went back to 212 and nothing. Anyone else have this? It is set to BL/FW and nada. Lastly I hooked up my GTB and it works fine.
Esc?
Any ideas yall?
Esc?
Any ideas yall?
What is a good starting point for an 8.5T on carpet 110ft straight in a TC. I was thinking around starting at 8 FDR and slowly adding boost and decreasing the FDR? Does this sound ok? What is a typical rpm range I should looking at?
I am a pan car racer, first time out of blinky with a TC. Thanks for the help guys.
Just curious how the factory replacement works. I have an rs that seems to work but the a post will get so hot it desolders itself. Do i just send it in with a cheque or does somone from tekin contact me for payment ect?
