Tekin RS ESC sensored
Super Moderator
I am running in blinking mode currently and I will see the two led's blink and then on occasion the first led will blink when the two blinking led's won't blink during this time. So it goes like this, two blinking lights for about 3-4 times and then the first led will blink and then it will return to the two blinking led's. It seems to do this in the same pattern continuously.
I am running it with a 3Pk radio so I am wondering if it is a neutral related issue?
It's either changed to the wrong motor type setting (brushed/brushless)or the motor has a bad connection on one or more of the windings. The last scenario is that some FET's have failed thus causing the "wrong Motor" LED indication.
This has happened to me and several of my friends who also run The RS.
You will see several others with the same problem if you look back in this thread.
R/C Tech Elite Member
what is the true purpose of using the silver cap on a rs pro? and what are the advantages if i used 2?
Hi guys
What's the latest software version for Rs pro?
I was thinking v212 is the latest but seen on the forum some people talking about v218....
Cheers
Cheers
yes
thats all here say
thats all here say
70m straight and flowing infield
Thanks Groomie
Trev
Super Moderator
Your speedo will run a little cooler with more caps --
only if you are using low turn motors it will help keep it cooler,there is no advantage in using more than one cap with high turn motors
So the purpose of the cap is to help cool the speedo and that's all?
