Tekin RS ESC sensored >
Old 03-20-2011, 04:07 PM
  #20026
pmc
Originally Posted by Nilks
In my experience, power-drop in the middle of the heat, is because of too tall of a gearing or bad batteries.
Hello Nilks
thanks to the answer.
we have new Lipos and two different brands.
we tried various final drive ratios and the motors was always cool in the 65 to 75 degrees celscius.
Best regards:
Pedro Silva
pmc is offline
Old 03-20-2011, 04:57 PM
  #20027
i am experiencing funny behaviour from my rs pro.
i am using a spektrum receiver and transmitter.
the problem is that if i go 100% throttle and then i slowly back off until neutral, the ESC remains stuck at around 10% throttle. So even with my trigger on neutral the car moves forward. If i slightly touch the brakes it stops.
Is there anything i can do?
i am using a custom profile in sensored mode.
min throttle is 10%
neutral width is 30 (i just realised i can try increasing this just in case it fixes it but i am currently charging batteries.)
omegaf is offline
Old 03-20-2011, 06:25 PM
  #20028
wingracer's Avatar
Trader Rating: 24 (100%+)
pmc, what are your timing settings? I find a bit too much timing can cause this, especially with the lrp motors.
wingracer is offline
Old 03-21-2011, 01:54 AM
  #20029
Talking
Hi, guys, anyone have a excellent setup for a X12 17.5 touring car for a asphalt track with a 22m straight and fdr to start. Just bought tekin and loaded v2.12 software on it. all help would be gladly appreciated.
2 Bar Boost is offline
Old 03-21-2011, 07:53 AM
  #20030
M-Technic's Avatar
Trader Rating: 15 (100%+)
If anyone is interested I ran mod with a non-pro RS and a 7.5t Trinity Nemesis last weekend. Here is my setup. It was running no problem with 4.5t's and had more rip. Track was very large and flowing, I'd say a 175ft straight.
T3 2011
Nemesis 7.5t
RS with v212
FDR: 8.1
Motor timing: +5*
start RPM: 6,000
end RPM: 32,000
timing boost: 46
turbo: 10
turbo delay: 0.3
turbo ramp: 2
throttle profile: 2
minimum throttle: 5
Temps were 180-190f after 5 minutes. Ambient temp was 85* and the track surface was 115-120*. The RS showed 3 to 4 lights for the temp.
M-Technic is offline
Old 03-21-2011, 08:21 AM
  #20031
20 SMOKE's Avatar
Trader Rating: 103 (100%+)
did you try 0 motor timing that may have dropped the temp down 10-15
20 SMOKE is offline
Old 03-21-2011, 08:42 AM
  #20032
M-Technic's Avatar
The timing ring was stuck
Old 03-21-2011, 09:09 AM
  #20033
20 SMOKE's Avatar
was it Potters
20 SMOKE is offline
Old 03-21-2011, 10:01 AM
  #20034
M-Technic's Avatar
Haha, it was Felix "more power" Law's.
Old 03-21-2011, 01:31 PM
  #20035
pmc
Hello
Boost 45
Turbo 14
Timing on motor is 4 dot insert.
Best regards
Pedro silva
pmc is offline
Old 03-21-2011, 02:37 PM
  #20036
wingracer's Avatar
Originally Posted by pmc
Hello
Boost 45
Turbo 14
Hm, that's not too awfully high. You could try backing it down a bit (40/10 maybe) but unless you are bringing the timing in way to quick/early, that shouldn't be the problem.
Old 03-21-2011, 02:56 PM
  #20037
pmc
Hello
Thanks to the help i will test this (40/10).
To see if solve the problem.
Best regards:
Pedro Silva
pmc is offline
Old 03-22-2011, 05:09 AM
  #20038
jrxs-r's Avatar
Trader Rating: 11 (100%+)
Originally Posted by Mr. MR4
I am currently using these settings in 1/10 TC 2s lipo:
Gearing - 5.8
Motor Timing - 1 notch + timing (GM13.5 - 12.3mm rotor)
Throttle Profile - 4
Boost - 48
Start RPM - 2850
End RPM - 12000
Turbo - 13
Turbo Delay - 0.16
Ramp - 2
Throttle Minimum - Max
The issue I have is that from 1% to 50% throttle on my transmitter, the power delivered to the motor remains the same. After 50% the boost kicks in and at 100% throttle the turbo kicks in.
Is there any way I can get the 1% to 50% throttle to increase gradually?
First off I would recommend decreasing you throttle minimum to around 0-5%, then increase your RPM range from let's say 7000 to 22000. Drop your motor timing to neutral or in the negative. Also, recalibrate the ESC to your TX again.
Try that and let us know.
jrxs-r is offline
Old 03-22-2011, 10:45 AM
  #20039
Change your throttle profile to 3, increase your end rpm, and possibly reduce your amount of timing.
Sounds like the motor is struggling with a the timing being thrown at it, and by the time it gets up to speed, your full throttle and it's throwing more timing at it!
JR007 is offline
Old 03-22-2011, 10:53 AM
  #20040
Mr. MR4's Avatar
Thanks for all the replies.
Just changed settings as recommended and already feels much better. Will have to test it at the track next and see how it goes.
Mr. MR4 is offline
