Tekin RS ESC sensored
Does anyone have a 1/12th scale Tekin setup for a 1c 3.7 lipo with a Speedpassion V3 13.5
Motor timing gearing etc,etc, im running on a 100 X 45 track
thanx
thanx
start 3k
end 6k
timing boost 40-50
turbo 0
motor 5-10
2.4 fdr(with full size tire)
More RS Set ups?
I'd like to know if Tekin is going to post some additional on-road RS set ups on their website? Team Snowbird set ups would be nice.
Hi there all rc lovers..
I would like to ask what is the command setting for 11.5t brushless motor ?
timing boost = ?
turbo boost = ?
turbo delay = ?
turbo ramp = ?
start rpm = ?
end rpm = ?
If i would like to set the motor more faster in in-field, how should i do it ?
Current fdr = 7.03...
timing boost = ?
turbo boost = ?
turbo delay = ?
turbo ramp = ?
start rpm = ?
end rpm = ?
timing boost = ?
turbo boost = ?
turbo delay = ?
turbo ramp = ?
start rpm = ?
end rpm = ?
timing boost = ?
turbo boost = ?
turbo delay = ?
turbo ramp = ?
start rpm = ?
end rpm = ?
Anyone got a setup for 1/12th with a 4.5t on a high grip track with a 30m straight, enough grip to use 203 with sensored mode.
BRAKES !!!!
When are we going to see this new software for the brakes, Im running 10.5 and the breaks are to weak. If this software isnt released soon Im going to have to try a different esc
some are adding a little reverse to slow it down with good results,they are back a few pages
Okay I got the hotwire in my computer- finally. Anyone have a set-up for a 13.5 with a short course truck (2wd).
DO NOT in ANY way add reverse to the unit trying to make brakes out of it. That will cause HUGE current spikes and you're going to ruin the esc.
You've been warned.
The latest software is in team hands right not under vigurous testing. There are some HUGE improvements to this software and it needs to be right. Bare with us...
You've been warned.
