Tekin RS ESC sensored
The x12 and Nosram equivalent went well with the Tekin, and I left it on 40deg timing as well. Ran it at 6.2 around WLRC.
Usually reached around 60degC
Skiddins
Skiddins
17.5 A-Main
13.5 A-Main
Charts provided by RcEvilEmpire.com
What Version Tekin Software for 1/12th Modified?
I will be running 1/12th modified using a 4.5 or 5.5 motor. Which Tekin software should I be using?
Thanks!
Thanks!
I was practicing with my T4 the other day and all of the sudden the throttle cut out. I thought I had hit the lipo cutoff. So I charged the battery and went out for the qualifier and I had no throttle. I looked at the ESC and the 1,2 and 6,7 lights were blinking meaning wrong motor type selected. I hooked it up to my laptop and everything was correct. So I reset it to the factory defaults and put all my settings back in to make sure everything was right. It did the same thing, so I tried a different sensor cable same result, then I tried a different motor and another sensor cable, same result again. Has anyone else had this problem? I have a Tekin RS.
did you flash to a old version 180/184/ect then go to 203
Thanks again, Rob.....
to much timing to fast causes heat,to low rpm is wasting the timing being applied
I seem to recall reading a few posts back that "no turbo" works well on a track with a short straight. Is that correct? I want to reprog for a new track I'll be going to with a short straight and tight infield.
Rob...........
less than 100ft is a waste,you can get more out of it with motor/timing boost gearing and rpm range
And believe me, his wasn't the only turbo equipped RS setup out there.
hi yeah sorry to say its dead as a door nail
mine happened just when i turned it on was fine before on the previous run with the same motor and settings just got ready for a race and it started flashing had to send it back to tekin said it was a short in the internal circuitry was unable to pinpoint the reason and there was no fixing it
just sent me new unit contact tekin mate
Hi
Thanks for the info. Ill have a look at the tekin site and go from there.
tekin virgin
Guys hoping someone can help me - jsut received my first tekin and have no clue about them.
1. Has anyone got an asphalt setup - mid to high traction - mid to large track - Tftr melbourne for anyone listening - I am running 21.5 and 17.5 - Sp v3
2. What is the latest software availiable for stock
3. When I plug in the equipment to my laptop it keeps telling me "Unhandled exception" - anyone with any clues as to what this is and how to fix it.
4. What is an ideal FDR for 21.5/17.5?
PM might be best to contact me if possible.
-=light=-
Looking for a set-up for my RS for a World Gt with a Nemisis 13.5 on asphalt. Will be running on a 1/8th gas track .
