Kyosho V-ONE RRR EVO 2
#2371
I use it on position 1, with 2mm spacer in the upright, and 3/3.5° static camber.
AFM
#2373
this is so sad!
i had a run away last week from a bad connection.
i made my chassis like a broken surfer board!
aouch!
aouch!
#2374
you can bend the motor mount, it is easy and happens to me a lot.
#2377
evo2 and evo chassis are the same there, the front was narrowed. im not sure why it sticks out either but most of the cars i can think of off the top of my head have the same thing. the kyosho mount is just not very strong. i dont know how it bends at all honestly considering it is closely bolted to the engine and then the chassis..
#2378
Trader Rating: 13 (100%+)
My opinion for what it's worth is that that part of the mount is really not that exposed; it is well inside tires. exhaust and layshaft side pulley. The hit would have to come from underneath to damage it; and whilst it obviously happens, but I'm surprised to hear that you have had it has happened a lot. I have never heard of this problem before.
There are other and more serious design flaws with the RRR in my opinion; for example that the front rims cut into the shock ball ends, if the caster is angled back. That could easily be fixed by using a ball end desing like Mugen or X-Ray.
Kindest regards,
Lars.
#2380
was bored and with a bunch of spare parts i came up with this
dax/dls on a rrr..
just gotta o some adjustments.
dax/dls on a rrr..
#2382
yes it works.... and i got it to work, but came across a few issues and took it apart at the end. was too much headache.
i may give it another try in the future, but would need the parts machined out for perfect fit.
1. was too unstable. too sloppy even when i tried to eliminate the slop from all the linkages.
2. if i grab one wheel and rock it back and forth (with enough pressure), i was able to make the opposide move.
I guess this is the reason why the serpent dls runs the linkage from the a-arm to the upper-arm. to prevent ^ from happening and the only way it would work is if lower arm is compressed.
i found a solution to fixing this, which is running a spring which prevents it from happening
3. made the rear end too stiff, too much 'sprung' mass
at the end it just looked like there was too much going on..
#2384
#2385
