Kyosho V-ONE RRR EVO 2
#2072
basic setup
hi guys...need some comments & feedback
this is for a parking lot race .. the track will only be setup one day before race day. and i do not have time to test it.. so i'm just assuming the conditions that i will face....the traction maybe low to medium . and more technical layout i guess.
so here's my setup that i propose.
-shocks fr 50wt with med spring, position mid hole
-shocks rear 45wt with med spring, pos 2nd from bottom
-fr diff 30k
-rear diff 20k
-droop fr 0 , rear 4
-caster middle
-anti rol bar fr softest. , rear 1.8 wire.
-track width 199 fr/rear 200
-ride height fr 7, rear 8
-rol centre fr top, rear 2nd from bottom
-cambers fr 1 , rear 3-4
-toe out fr 1, toe in rear 2.5-3
- i will be running tyres dia. 59 fr, 61 rear for heats
tqvm
-fr diff 30k
-rear diff 20k
-caster middle
tqvm
#2073
-fr diff 30k
-rear diff 20k
-caster middle
tqvm
-fr diff 30k
-rear diff 20k
-caster middle
tqvm
id atleast go 50k at the front & 20k at rear... but ill let someone else comment on this.
#2074
it depends on what type of driver you are and how serious you want to be, that setup looks ok.. i don't use front diffs yet so i can't comment on the oil but it should be drivable on almost anything like that. the rrr has such a huge sweet spot in the setup that makes it usable on almost any surface. tires will be the most important thing you can pick. could be 45's, could be 33's..
#2075
-fr diff 30k
-rear diff 20k
-caster middle
tqvm
-fr diff 30k
-rear diff 20k
-caster middle
tqvm
#2077
it would be good if they made hexheads instead of the screwdriver heads.
#2078
kyosho makes so many odd decisions but plenty of other cars come with philips heads too, its annoying.
#2079
Trader Rating: 13 (100%+)
I drilled mine all out to 3mm screws mostly to avoid stripping the heads and use hexes. I run the aluminum middle pulley mount as well, you have to put a new angle on your battery tray as well but most of us have a countersink bit right?
For anyone that insists to stay with the original; you can get 10mm long Phillips head bolts and to cut to size at: http://www.rcscrewz.com/product_info...36b3131565e8aa.
Kindest regards,
Lars.
#2081
update
-fr diff 30k
-rear diff 20k
-caster middle
tqvm
-fr diff 30k
-rear diff 20k
-caster middle
tqvm
to summarize things , the car perform well but there still room to improve few setups here n there on that particular track.
once again thanks guys n happy racing...wil try out those setups that u guys mention .
cheers.
#2082
might look into it in the future though..
looking into a YBSLOW battery plate as im running a LiFe and a few other lightweight pieces.. my car is around 1650-1670 with shell on. Im running a one way, but installing a diff, so that should push it up abit.. but still gunna be very light, under 1700.
dunno if i should run a 42g so it just weighs above legal or a 58g.
#2083
Perfect and sick fast - RRR evo 2 w/ RB V12 "Rody" & pipe
Could run circles around those LRP12 powered RRR's
More photos in my facebook.. just send me a friend invitation... cheers
http://www.facebook.com/profile.php?...56&ref=profile
#2084
i was thinking of doing that.. i dont remove my battery plate that often anyway. and i got a few spares of that size.
#2085
Kindest regards,
Lars.
